LS V-Tech Early stages
Old Mar 28, 2006 | 02:13 PM
oianarchy's Avatar
Default LS V-Tech Early stages
Im at the early stages of an LS V-Tech build
this is the first motor thats all mine!!!
The block is a 95 b18a standard bore
Im planning on using:
probe high comp Pistons
probe rods
The head is a 99 B16a
i have skunk2 stage2 cams
skunk2 springs and retainers
*need valves*
What comp do you recomend for the pistons? lets not get out of hand it maybe a daily driver at some point soon
If i have skunk2 springs and retainers should i use Skunk2 valves or can i go with JG Engine dynamics flat faced valves?
Let me know what you all think
Modified by oianarchy at 8:40 PM 3/28/2006
Old Mar 28, 2006 | 02:25 PM
Dan Ruddock's Avatar
Default Re: LS V-Tech Early stages (oianarchy)
The stock valves work fine don't waist your money. As far as your cr goes I don't recommend more than 11.0 to 1 for a pump gas motor. Some on this board think I crazy about this but if they don't want maximum life out of there motor that is there choice. As far as your piston choice I would use some oem cast pistons. Better for street use unless you want to run a lot of nitrous. You will have to run arp/ls rods with oem pistons. Dan
Old Mar 28, 2006 | 02:55 PM
DonF's Avatar
Default Re: LS V-Tech Early stages (Dan Ruddock)
Just curious,why would you reccomend 7 year old used valves VS new ones?
Old Mar 28, 2006 | 03:09 PM
oianarchy's Avatar
Default Re: LS V-Tech Early stages (DonF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF &raquo;</TD></TR><TR><TD CLASS="quote">Just curious,why would you reccomend 7 year old used valves VS new ones?</TD></TR></TABLE>
yeah my valves are done. I deffinitly need new ones, should i still use stock ones or go flat faced?
Old Mar 28, 2006 | 03:32 PM
If the stem wear is in spec there is nothing wrong with old valves unless you are talking about an air cooled VW exhaust valve. Dan
Old Mar 28, 2006 | 03:50 PM
JCushing's Avatar
some one had to mention the VTECH so it might as well be me
VTECH hehe
Old Mar 28, 2006 | 03:54 PM
UNKNOWN_MEMBER's Avatar
Default Re: LS V-Tech Early stages (JCushing)
just get the omnipower valves. uses the same material as OEM, with a flat faced to give more compression.
Old Mar 30, 2006 | 01:48 PM
oianarchy's Avatar
Default Re: LS V-Tech Early stages (UNKNOWN_MEMBER)
how bout pistons and rods. Im not trying to spend a **** load but im not trying to buy junk either. Drop a link
Old Mar 30, 2006 | 01:57 PM
D-Rob's Avatar
Keep the stock LS rods, and fasten them to the crank with some 8mm ARP rods bolts.
Also look into PR3 or P30 pistons. They must be pressed on the rods, because they are a factory piston. Both of those can be found in different variations of the B16.
With the PR3's, you'll be at around 11.3:1 compression, and with the P30's you'll be around 11.5:1 compression.
I personally run the P30's.
- Derek
Old Mar 30, 2006 | 02:16 PM
DC2 Mang's Avatar
You can run more than 11:1 compression on pump gas
mine is at 11.8:1 running on 91 octane
it is all in the tuning
Old Mar 30, 2006 | 02:21 PM
D-Rob's Avatar
Default Re: (JDMdc2lsVtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMdc2lsVtec &raquo;</TD></TR><TR><TD CLASS="quote">You can run more than 11:1 compression on pump gas
it is all in the tuning</TD></TR></TABLE>
I second that.
Old Mar 30, 2006 | 02:25 PM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: (D-Rob)
If you go with p30 pistons, your compression ratio will be closer to 12.1:1 see the following site below:
http://www.zealautowerks.com/
Old Mar 30, 2006 | 02:26 PM
mar778c's Avatar
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan Ruddock &raquo;</TD></TR><TR><TD CLASS="quote">If the stem wear is in spec there is nothing wrong with old valves Dan</TD></TR></TABLE>
Nice answer
Old Mar 30, 2006 | 02:27 PM
D-Rob's Avatar
Default Re: LS V-Tech Early stages (mar778c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mar778c &raquo;</TD></TR><TR><TD CLASS="quote">If you go with p30 pistons, your compression ratio will be closer to 12.1:1 see the following site below:
http://www.zealautowerks.com/</TD></TR></TABLE>
...Not with a B16 head, chief.
EDIT: That compression calculator contradicts the widely used C-Speed Racing one.
Old Mar 30, 2006 | 02:31 PM
oianarchy's Avatar
Default Re: (mar778c)
That site is cool as ****
Old Mar 30, 2006 | 02:33 PM
D-Rob's Avatar
Default Re: (oianarchy)
May be 'cool as ****,' but many consider it incorrect.
Old Mar 30, 2006 | 02:34 PM
DC2 Mang's Avatar
Default Re: LS V-Tech Early stages (D-Rob)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-Rob &raquo;</TD></TR><TR><TD CLASS="quote"> That compression calculator contradicts the widely used C-Speed Racing one.</TD></TR></TABLE>
C-speed is the only one I really trust, my set up is wth p30 pistons and a gsr head, I punched in the number and an 11.8:1 came out
all other calulators ive used have said 12.4:1 or something higher and seemed way off, c-speed knows what they are doing
Old Mar 30, 2006 | 02:36 PM
D-Rob's Avatar
Default Re: LS V-Tech Early stages (JDMdc2lsVtec)
all other calulators ive used have said 12.4:1 or something higher and seemed way off, c-speed knows what they are doing </TD></TR></TABLE>
Exactly. Thank you.
Old Mar 30, 2006 | 02:37 PM
oianarchy's Avatar
lol
Old Mar 30, 2006 | 02:44 PM
oianarchy's Avatar
Do you think 11.8:1 good for a daily driven motor?
Old Mar 30, 2006 | 02:53 PM
mar778c's Avatar
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-Rob &raquo;</TD></TR><TR><TD CLASS="quote">May be 'cool as ****,' but many consider it incorrect.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMdc2lsVtec &raquo;</TD></TR><TR><TD CLASS="quote">
Well, during the compression ratio debate the c-speed calculator at the time seemed to be off by quite alot especially concerning PCT pistions.
If you know the correct piston to deck hieght then it seems to work.
see here
https://honda-tech.com/zerothread?id=1245459
and here
https://honda-tech.com/zerothread?id=717928
That thread used to be a sticky.
Like anything it should be used with advisement.
EDIT: That compression calculator contradicts the widely used C-Speed Racing one.</TD></TR></TABLE>
Go back and read a little more, little indian.
Old Mar 30, 2006 | 03:15 PM
hondaboyB18C1's Avatar
it's VTEC not v-tech , that is a phone
Old Mar 30, 2006 | 03:25 PM
oianarchy's Avatar
Default Re: LS VTEC Early stages (hondaboyB18C1)
oops
Old Mar 30, 2006 | 03:26 PM
oianarchy's Avatar
Default Re: LS VTEC Early stages (oianarchy)
Old Mar 30, 2006 | 03:31 PM
D-Rob's Avatar
I daily-drive my P30/B16 headed-LSVTEC.
It burns some oil and smokes, but that's my valve seals.
