Need Help. Code 6: Water Temp Sensor
Old Mar 28, 2006 | 01:47 PM
b18cEK's Avatar
Default Need Help. Code 6: Water Temp Sensor
I am throwing Code 6 and I am wondering if that could be the reason why my car won't start?
It's a 92 hatch with jdm d15b...
Old Mar 28, 2006 | 01:51 PM
NJcoupe's Avatar
Most likely not the reason.
Have you narrowed things down such Fuel,Spark, Compression?
Old Mar 28, 2006 | 01:55 PM
HB VTEC's Avatar
code 6 is your cooling fan....sheck the plug next to the resoivor tank...check fuses under the dash
Old Mar 28, 2006 | 01:58 PM
b18cEK's Avatar
Default Re: (idriveacoupe.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by idriveacoupe. &raquo;</TD></TR><TR><TD CLASS="quote">Most likely not the reason.
Have you narrowed things down such Fuel,Spark, Compression?</TD></TR></TABLE>
I've done fuel and spark. guess i better check compression
Old Mar 28, 2006 | 02:05 PM
b18cEK's Avatar
Default Re: (civic-rmod)
can you rent a compression gauge from advance auto parts?
Old Mar 29, 2006 | 03:09 AM
NJcoupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic-rmod &raquo;</TD></TR><TR><TD CLASS="quote">can you rent a compression gauge from advance auto parts? </TD></TR></TABLE>
No, but they're around $30. Also check your timing.
Old Apr 22, 2006 | 12:23 PM
hondatuner123's Avatar
Default Re: Need Help. Code 6: Water Temp Sensor (civic-rmod)
hey yah. its probably the reason. keep cranking it over for like 20 seconds and press on and off the gas pedal. it might fire up. thats what my hatch with the d15b swap did when my sensor was fucked up. replaced it and no codes
dc4teg95
Nov 6, 2007 04:18 AM
P@@RB@Y
Nov 16, 2005 12:39 PM
blowme
May 2, 2005 04:38 AM
DjFreeze
May 15, 2004 06:47 AM
maka
Feb 23, 2004 08:27 AM
