Synthetic oil causing B16A2 to burn oil?
Old Mar 28, 2006 | 11:09 AM
tommy.'s Avatar
Default Synthetic oil causing B16A2 to burn oil?
Could synthetic cause oil burning?
Motor has 110k miles..........maybe my rings are gone
Old Mar 28, 2006 | 11:12 AM
GS-R Civic's Avatar
Default Re: Synthetic oil causing B16A2 to burn oil? (eg6b0i)
What is the weight of the oil and how often do you change it?
Old Mar 28, 2006 | 11:14 AM
lonefuzzy79's Avatar
On an older engine synthetic can cause your engine to burn oil. Synthetic will eat through deposits and sometimes older gaskets and becuase it is lighter than dyno oil can seep past rings. If you have never used synthetic before, go back to mineral oil.
Old Mar 28, 2006 | 11:19 AM
civic93@8psi's Avatar
what brand & weight of oil were u using
MY Si burned a quart of castrol fully synthetic by 3000 miles so i switched back to mobil one stays full till 5000 miles 5w30 and i only had 40,000 miles on the motor
-mike
Old Mar 28, 2006 | 11:23 AM
tommy.'s Avatar
mobil 1 5w30...
Old Mar 28, 2006 | 11:35 AM
DAMN i live by mobil one how bad is it burning?
-mike
Old Mar 28, 2006 | 11:57 AM
DannyDeuce's Avatar
Default Re: (civic93@8psi)
10w30 Castrol High Mileage oil Works great for me.
DAN
Old Mar 28, 2006 | 12:01 PM
shatchi's Avatar
Default Re: (DannyDeuce)
I once did that on my gsr motor too, I was using 10W30 motor oil, then i went full-syn, then i burnt it really bad. Now Im using syntec-blend from castrol.
Old Mar 28, 2006 | 12:06 PM
hondadriver's Avatar
I had a JDM 2nd gen b16a, and at first i used regular non-synthetic oil and everything was fine. then I started to use royal purple and like 2 months later I started burning oil and it smelled like **** when i got on it (about a quart every 1000 miles)!!! So i talked to a local peformance shop about getting cams installed and my valve seals replaced. because i did a compression test and that was fine. Well i waited to long and I spun the 1st and 2nd rod bearing!!! My fault obvious for not checking the oil. When I took my head off after I spun the bearings there was oil soaked around my intake valve in the first cylinder But I'll never use synthetic again unless its a new motor!!!!!
Old Mar 28, 2006 | 12:50 PM
riceburnerryan's Avatar
i burn a little bit of oil while using synthetic, i heard its kinda bad to go from synthetic back to regular?? is that true?
Old Mar 28, 2006 | 01:03 PM
Default Re: (riceburnerryan)
Its not bad to go back to regular, but you can't fix the damage (if any) done by the synthetic by just going back to the regular!!! So if you have a leak from using the synthetic oil then the leak will still be there no matter what oil you use!!!
Old Mar 28, 2006 | 01:31 PM
o2flow.net's Avatar
compression test
leakdown test
then start talking about switching weight
Old Mar 28, 2006 | 03:31 PM
95b16hatch's Avatar
try a compression test or a leak down test.
Old Mar 28, 2006 | 03:51 PM
bsixteen's Avatar
i have 163k+ on my car and i've been using mobile 1 synthetic 5w30 ever since i got the car(at 124k). i should probably measure how much oil i drain but my car doesn't seem to be hurting any.
EG-SIXV-TEC
11
Dec 13, 2012 02:45 PM
purplevtec
Nov 21, 2004 01:01 PM
vtechatch
Dec 30, 2002 10:31 PM
Lei Siew Long
Feb 3, 2002 07:43 AM
TypeR01-424
Aug 17, 2001 07:51 AM
