window problem on 93 coupe...help fast!
Old Mar 28, 2006 | 10:38 AM
5thgencivicr's Avatar
Default window problem on 93 coupe...help fast!
my coupes drivers side power window switch is broekn becuase only the passenger window will go up/down. is there any way to manually crank up a power window? i need help asap thanks.
Old Mar 28, 2006 | 10:39 AM
BauleyCivic's Avatar
Risky Business
Default Re: window problem on 93 coupe...help fast! (5thgencivicr)
I'd imagine you just take the doorpanel off, disconnect the belt and do it by hand...
Old Mar 28, 2006 | 10:43 AM
Default Re: window problem on 93 coupe...help fast! (BauleyCivic)
belt? i have the door panel off im looking for something like the sunroof has incase that breaks it has a manual crank. there is no belt. (hope you werent serious)
Old Mar 28, 2006 | 10:57 AM
Risky Business
I hope this is of some help...it's copied directly from the helms. Its how to remove the glass and regulator.
Old Mar 28, 2006 | 11:48 AM
john666's Avatar
couldnt u just like hot wire it to close the window .
Morasso
Sep 10, 2009 05:31 AM
ModdedByA1auto
Mar 10, 2009 08:56 AM
lamboextreme
Oct 20, 2007 09:25 AM
t3traknot
Sep 8, 2007 11:10 PM
4Dinsaneb16
Mar 20, 2007 01:30 PM
