timing belt question
Old Mar 28, 2006 | 08:56 AM
beany's Avatar
Default timing belt question
okay no matter what i do, i cannot get my motor timed correctly. i even took it midas and they couldn't time it without taking the timing belt off and re adjusting it because it was off a few teeth. and they want almost 200$ to do it =/. so i was wondering if i took off the timing belt myself, how would i put it on so it WONT be a "Few" teeth off? is there any certain way to tell? i searched but coudln't find anything relating to my question.
Old Mar 28, 2006 | 08:59 AM
JonB730's Avatar
Default Re: timing belt question (beany)
are they factory gears or aftermarket?
Old Mar 28, 2006 | 09:07 AM
beany's Avatar
Default Re: timing belt question (JonB730)
factory, everything is stock. motor is a d15b7
Old Mar 28, 2006 | 12:04 PM
beany's Avatar
bump
Old Mar 29, 2006 | 12:06 AM
beany's Avatar
bummp^
Old Mar 29, 2006 | 12:47 AM
fmrprojects's Avatar
Default Re: (beany)
just make sure its on correct, turn it a few times and see if it goes back to the same spot,, then time the car
Old Mar 29, 2006 | 05:37 AM
rig9896's Avatar
Default Re: (fmrprojects)
Are you using the timing marks on the timing belt cover, pulley, and cams? You take off the valve cover losen the tensioner, then slide the belt off the cams. Then set everything to TDC (using all the marks previously stated). With the tensioner loose, you place the belt back on the cams, then turn the crank a little bit to adjust the tension. Tighten the tensioner pulley, then rotate the crank to see if everything lines up. Make sure you rotate the crank the correct way though. Do you own a helms manual? They are very helpful.
stevenDAtegra
May 7, 2009 09:56 PM
integra3586
Sep 25, 2006 03:57 PM
handa
15
Oct 26, 2004 09:35 AM
TurboDANDEE
Dec 1, 2002 08:29 PM
