Speedo Cable Problem
Old Mar 28, 2006 | 07:01 AM
saikouEF8's Avatar
Default Speedo Cable Problem
My speedo cable was making loud chirping noises. it wa sobviously going bad... no amount of lude would make it stop. wd40 made it worse. anyways im goin to replace it .... but i went to drive the car today and it wasnt making the chirping noises and the speeddo wasnt moving. then the check engine light came on. does this sound normal? im assuming its ok cuz the cable probly stopped working all together. car runs fine... actually it may be my imagination, but it runs even smoother. .... thoughts?
Old Mar 28, 2006 | 08:52 AM
Ak_ef9's Avatar
Default Re: Speedo Cable Problem (saikouEF8)
its probably running a vss code. Just replace the speedo and you should be good to go and reset the ecu and there should be no more cel.
ps: I got a vss for sale for 13 shipped if you want it.
Old Mar 28, 2006 | 09:42 AM
red_EF9Si's Avatar
gsr cluster conversion anyone? i have an extra laying around. also i have a good cable and good vss if you need em.
GPC91
Sep 17, 2012 01:11 PM
949
14
Aug 23, 2010 10:43 PM
dusterbd13
Oct 19, 2009 06:47 PM
DraginTeg93
Dec 4, 2008 10:00 AM
DOHCRX
Mar 28, 2003 08:22 PM
