Old Mar 25, 2015, 12:17 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Lighting
Print Wikipost
DIY JDM black housing headlights
Old Mar 27, 2006 | 11:57 PM
H.'s Avatar
H.
Default DIY JDM black housing headlights
well i got the shitty chrome ones and they sucked decided to do it myself and make them black housing ......
Tools needed:
Small philips screwdriver
Oven
Tinfoil
Cookie sheet
High-temp spray paint
Painting tape (I recommend 3M #2080, 3/4" or smaller width)
Small flathead screwdriver (optional)
Step 1: Preheat the oven to about 300°F.
Step 2: Get a cookie sheet and lay some tinfoil on it. Remove the four metal clips from the headlights. I found it unnecessary to remove bulbs or rubber pieces.
Step 3: Heat one headlight at a time for 7-8 minutes until the sealant is gooey. Make sure to cover it in tinfoil first, exposing only the seam, then place it on the cookie sheet. Try not to let any part of the headlight touch the walls, the rack, or especially the heating coils of the oven.
Step 4: Remove this screw while the sealant is still soft.
Step 5: Pry up the plastic tabs carefully and carefully separate the housing. You may want to use a small flathead to get it started, but be very gentle.
Step 6: Once you have the headlight open, set the projector part of the housing aside. Unscrew the four screws that hold the chrome housing to the clear plastic headlight lens.
Step 7: Carefully remove the chrome housing from the lens, making sure not to get any sealant stuck on the chrome housing. You now have three pieces.
Step 8: Using your painter's tape, mask off the chrome ring around the headlight projector, the turn signal lens, and the back part of the highbeam section.
As is the case whenever you are masking anything, THIS STEP IS CRITICAL. How good of a masking job you do will determine how good your headlights will look in the end. The hardest sections to mask are the curved sections and the chrome ring around the projector. In these cases it is best to use small strips of tape overlapping each other to get the mask as round as possible. It is somewhat better to overspray very little and later remove it than to mask too much and have to mask and spray it again.
Step 9: In a well-ventilated and dust-free area, put your chrome housing on a drop cloth or newspaper, etc. and apply light, even coats, starting off of the housing, moving across slowly, and ending off the housing. Be sure to turn over the housing and get all the areas on the underside that you may have missed.
Step 10: After the housings have dried, reassemble everything in reverse order and admire your work! Make sure you put in that last screw while the sealant is still gooey.
The final product:
Old Mar 28, 2006 | 12:12 AM
H.'s Avatar
H.
Default Re: (cire)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cire &raquo;</TD></TR><TR><TD CLASS="quote">not too bad. you could even do the diy halos while you had it apart (if you like halos)</TD></TR></TABLE>
thanks, but im not a big fan of halos....next project HID retrofit
Old Mar 28, 2006 | 12:30 AM
.water's Avatar
Default Re: DIY JDM black housing headlights (JDMDC4..)
nice just that i dont have JDM front end...lol
Old Mar 28, 2006 | 01:50 AM
Sifu's Avatar
I remember seeing your thread on ti.net a while back and it gave me the inspiration to do it on mine. I did it about 2 months ago but it didnt turn our quite as nice, did you get a sharp edge on your circle?
Old Mar 28, 2006 | 09:58 AM
H.'s Avatar
H.
Default Re: (Sifu)
lets see some pics of yours
Old Mar 28, 2006 | 10:05 AM
teggy182's Avatar
Default Re: (JDMDC4..)
damn thats a good job
Old Mar 28, 2006 | 10:14 AM
CNSK's Avatar
black housing looks better then chrome.......
Old Mar 28, 2006 | 10:19 AM
ChicagoMike's Avatar
Default Re: DIY JDM black housing headlights (CNSK)
Good write up and finished product!! I did the same thing to my civic headlights
I think yours turned out better though.
Old Mar 28, 2006 | 10:49 AM
H.'s Avatar
H.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CNSK &raquo;</TD></TR><TR><TD CLASS="quote">black housing looks better then chrome.......</TD></TR></TABLE>
duh
Old Mar 28, 2006 | 11:10 AM
plusONE DC2's Avatar
nice DIY, does that mean you dont need my black set
Old Mar 28, 2006 | 11:23 AM
H.'s Avatar
H.
Default Re: DIY JDM black housing headlights (plusONE DC2)
sorry, but yah no more ITR when i already have some wannabes
Old Mar 29, 2006 | 12:56 AM
manyakiexpi's Avatar
do u have ne pix of what the headlight is suppose to look like when its covered in foil when u put it into the over?
looks nice
Old Mar 29, 2006 | 01:27 AM
kcjohnnyboy's Avatar
what type of silicone sealant do you use to seal the headlights back up? and where do you get it?
Old Mar 29, 2006 | 06:14 AM
TURBODC4TEG's Avatar
Default Re: DIY JDM black housing headlights (kcjohnnyboy)
nice, good job
Old Mar 29, 2006 | 06:24 AM
DoMiNiCaNoDa9-Jtech's Avatar
nice write up
Old Mar 29, 2006 | 06:35 AM
juicy.fn's Avatar
Default Re: DIY JDM black housing headlights (DoMiNiCaNoDa9-Jtech)
nice DIY, now go do that retrofit!
you planning on using s2ks? they are same as the JDM HID headlights
Old Mar 29, 2006 | 06:01 PM
Stryker's Avatar
my headlights don't fit in my oven
Old Mar 29, 2006 | 07:27 PM
OMG THE GOGGLES's Avatar
Default Re: (Stryker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stryker &raquo;</TD></TR><TR><TD CLASS="quote">my headlights don't fit in my oven</TD></TR></TABLE>
Ditch the toaster oven.
Old Mar 29, 2006 | 07:33 PM
nautica_t's Avatar
looks really nice. good job,
Old Mar 29, 2006 | 09:19 PM
Stryker's Avatar
Default Re: (gasper44`)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gasper44` &raquo;</TD></TR><TR><TD CLASS="quote">
Ditch the toaster oven. </TD></TR></TABLE>
No seriously, my healights won't fit i need help!
Old Mar 29, 2006 | 09:32 PM
SlamminS85's Avatar
you can use a:
Heat Gun
Hair Dryer
or a variable temperature soldiering iron with a flat head screwdriver like tip (this is the hardest not to screw up)
Old Mar 30, 2006 | 02:00 AM
Sifu's Avatar
No seriously, my healights won't fit i need help!</TD></TR></TABLE>
Lol that **** is true, my one doesnt fit my oven either. Damn you americans with your fat ovens
BTW I used a hair dryer and it was perfect (y)
Old Mar 30, 2006 | 02:26 AM
MugenDC4's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kcjohnnyboy &raquo;</TD></TR><TR><TD CLASS="quote">what type of silicone sealant do you use to seal the headlights back up? and where do you get it?</TD></TR></TABLE>
I was wondering the same or did you use the same sealant that was already on the headlights?
Old Mar 30, 2006 | 08:58 AM
Mr. Bob Dobalina
Guest
Posts: n/a
You did a good job...but why?
The SiR chrome housing headlights are dope looking.
To each their own.
Old Mar 30, 2006 | 12:54 PM
Stryker's Avatar
holy crap did this take forever, using a heat gun sucks *****, and my outer housing is all bent out of shape this sucks, but they do look good though when the hood is shut
