itr needs engine rebuild parts list needed
Old Mar 27, 2006 | 09:45 PM
itr1235's Avatar
Default itr needs engine rebuild parts list needed
well she has started burning lots off oil with a 197xxx km on the clock doing the rebuild in the next month what parts should i change when rebuilding?
Old Mar 28, 2006 | 05:46 AM
ProjektR's Avatar
Default Re: itr needs engine rebuild parts list needed (itr1235)
wow that's a lot of miles!
Old Mar 28, 2006 | 05:53 AM
Dave_B's Avatar
Since he wasn't any help...
I would say all bearings, maybe head bolts, rod bolts (these things tend to stretch, but you can have them checked to see if they are still within spec) Maybe valves/valve job depending on condition. Piston rings, hone/bore on the block, and depending maybe new pistons. Basically it really depends on budget, and condition after those miles. Another thing I would definitely do is valve seals. HTH
Old Mar 28, 2006 | 06:08 AM
ProjektR's Avatar
Default Re: (Dave_B)
Yea what he said. And if you haven't already changed them a new water pump, oil pump, hoses and cap & rotor.
Old Mar 28, 2006 | 07:10 AM
Batoutahell's Avatar
Default Re: (ProjektR)
Good advice above. With that kind of mileage, I'd also consider cleaning your injectors, timing belt and tensioner, rear seal, all the gaskets in the head kit.
Old Mar 28, 2006 | 07:12 AM
white rocket's Avatar
Budget is key here. Do you want an OEM build or something a little more hardcore?
When my motor takes a p00p on me I will be doing the following: Benson 85mm sleeves, balanced/machined crank, Eagle rods, ARP rod bolts, CP 12:1 pistons, metal HG, P&P head, Supertech valves(stock size) and valve train, undecided cams, 310 inj. and all the supporting parts like bearings, valve guides, oil and water pump, gaskets, seals, etc.
Better refinance my house now
Old Mar 28, 2006 | 07:25 AM
redGSRguy's Avatar
Default Re: (white rocket)
Do something similar to what white rocket said! Are you doing most of the work yourself? When I got my engine rebuilt I figured I'd upgrade some things since I was already paying to get it rebuilt, might as well make it better!
Old Mar 28, 2006 | 08:51 AM
itr1235's Avatar
Default Re: (redGSRguy)
i don`t use the car for auto x, i just like driving the thing, i don`t do burn outs or thins like that my friends probally do when they have it. but should i use all oem parts or should i use better parts. i have reason to sell the car, cause there is nothing out i would replace it with. thanks
Old Mar 29, 2006 | 05:00 AM
ProjektR's Avatar
Default Re: (itr1235)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr1235 &raquo;</TD></TR><TR><TD CLASS="quote"> i have reason to sell the car, cause there is nothing out i would replace it with.</TD></TR></TABLE>
Only thing I'd replace mine with IF I had the money would be the new Skyline GTR
FlashfmDB8
Aug 6, 2013 05:40 AM
type_r_ek
Jul 30, 2012 06:33 PM
JDMguy88
Dec 8, 2010 03:26 PM
IBriaIN
Mar 2, 2010 07:28 PM
Jabinya
Jul 26, 2008 07:54 PM
