2 Cylinders Sparking WTF
Old Mar 27, 2006 | 09:08 PM
redhondacivic's Avatar
Default 2 Cylinders Sparking WTF
Alright that is exactly my problem. I am getting spark at 2 and 3 but not 1 and 4. New cap, new rotor, new plugs, new wires. What exactly controls the spark on a DOHC VEETACKS motor? I mean is it something inside my distributor. Mechanical timing is perfect, ignition timing should be right on. Plug wires should be right but either way I would get a spark eventually from the plug. I pulled the plug from the #1 cylinder and watched it hoping to see something while it ran but nothing. No spark! WTF.
Old Mar 29, 2006 | 08:34 AM
crv-techu's Avatar
Default Re: 2 Cylinders Sparking WTF (redhondacivic)
test your coil o ignighter
Old Mar 29, 2006 | 03:58 PM
Sleeping_H22_DC2's Avatar
Default Re: 2 Cylinders Sparking WTF (crv-techu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crv-techu &raquo;</TD></TR><TR><TD CLASS="quote">test your coil o ignighter</TD></TR></TABLE>
well i think if it was his coil no cylinders would fire. Its got to be your rotor or distro cap if you are recieving sparks in the other cyl !
Old Mar 29, 2006 | 04:09 PM
Default Re: 2 Cylinders Sparking WTF (Sleeping_H22_DC2)
actually edit*
if your getting spark in the other cylinders probably not your rotor either because its sending spark to the others. I say Distro cap tell them its bad you need a new one that where i would start. then take a ohm meter check the resistance on the coil see what it reads hell get a new one while your their if it still dosen't work take it back. then if that doesn't might be your ICM
my money is on the distibuter though
97civic07gsxr
10
Apr 6, 2009 07:16 AM
ex_ricer
Aug 14, 2008 02:14 PM
ls19integra95
Apr 15, 2007 11:40 AM
MoBlack
Nov 28, 2005 09:47 AM
s2kkk
20
Apr 15, 2004 11:12 AM
