Suspension & Brakes Theory, alignment, spring rates....
tranny end of axle loose?
Old Mar 27, 2006 | 08:54 PM
modulo_s's Avatar
Default tranny end of axle loose?
whew
i just finished replacing my driver's side axle, but i'm not sure if it is seated all the way against the tranny case or not. i test drove it and it seemed fine except for the noticeable alignment difference.. can anyone advise? thanks in advace
Old Mar 28, 2006 | 04:05 AM
yellowrexsi's Avatar
Default Re: tranny end of axle loose? (modulo_s)
Unless you have the wrong axle, or you didn't put everything back correct. It shouldn't have change. You can look at the tranny to make sure the axle is tight to it. Just compare it to the other side.
fin781
Aug 15, 2012 06:22 PM
Momentum
Sep 2, 2010 10:06 AM
rexxb16
Aug 29, 2007 09:56 AM
ek_slut
May 12, 2005 08:11 PM
Psyco609
Sep 12, 2004 09:26 AM
