220v in my garage
Old Mar 27, 2006 | 06:57 PM
redsunsx01x's Avatar
Default 220v in my garage
whats up guys. im trying to save up to get my first welder and i was wondering how much did you guys pay to get a 220v in a garage? I got back from wyotech where i learned to weld and fabricate in my chassis fab class and i am itching to get back into making stuff.
Old Mar 27, 2006 | 09:24 PM
stealth-wrx's Avatar
I spent about $200 for everything. That was 50 feet of 6 gauge for each 110, and 50 feet of one 8 gauge neutral. The conduit is cheap and the receptical was about $15. The wire definately cost me the most money. The dual 60 amp breakers was only $10.
Old Mar 28, 2006 | 12:43 AM
19civic93's Avatar
Default Re: (stealth-wrx)
do it yourself it's real easy. save youself the 2-300 bucks and buy a bigger welder. only takes about 15 minutes depending on the length of the run. my outlets are right below my service panel. not sure if you can see it in this pic but there are 2 outlets to the right of the compressor. 1 is on a 60 amp and the other is on a 50 amp dual breaker. 6 gauge and 8 gauge respectively. a you have to do is remove the panel over the service panel. punch out an access hole for the wires. run a wire into the service panel and the other end to the outlet. connect the ground and 2 hots to the outlet and then mount the outlet to the wall. on the panel side connect the ground to the ground bus and the 2 hots to the breaker. once that's done make sure the breaker is in the tripped position and slap the breaker in. if you comfortable enough you can do it hot. i did all mine hot. there are no risks until you slap the breaker in. just be careful when slapping it in. i did my compressor too. that one is hard wired straight to a 30 amp breaker using 10 gauge.
Old Mar 28, 2006 | 07:42 AM
legendboy's Avatar
Default re
since this is your first post i guess this is a good time to tell you to use the search feature
https://honda-tech.com/zerothread?id=1373496
Old Mar 28, 2006 | 07:44 AM
legendboy's Avatar
Default Re: re (legendboy)
and 19civic93, resize your damn picture
Old Mar 28, 2006 | 10:57 AM
SL0WEGG's Avatar
i wish my breaker box was in the stinkin garage.
Old Mar 29, 2006 | 05:33 AM
Default Re: re (boostedej1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedej1 &raquo;</TD></TR><TR><TD CLASS="quote">i wish my breaker box was in the stinkin garage. </TD></TR></TABLE>
right that would make life soo much easier.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by legendboy &raquo;</TD></TR><TR><TD CLASS="quote">since this is your first post i guess this is a good time to tell you to use the search feature
https://honda-tech.com/zerothread?id=1373496</TD></TR></TABLE>
yeah ive been here off an on just really never posted here. and link=saved thanks ill remember next time.
Old Mar 29, 2006 | 05:40 AM
ccfab's Avatar
Default Re: re (redsunsx01x)
i tied 2 regular extension cords together and made sure they we seeing power by grabbing the ends of each and plugging it in.
tempsohc
Audio / Security / Video
Jul 31, 2013 09:30 PM
dohcvtak
May 21, 2009 09:11 PM
Jonathan_ED3
Welding / Fabrication
14
Aug 28, 2004 10:45 AM
trooper0641
12
Jul 8, 2004 03:39 PM
BlackAckeR
Jan 19, 2002 08:27 PM
