why is my H22 acting like this?????????? WTF
Old Mar 27, 2006 | 03:56 PM
BALLIN H22 EK's Avatar
Default why is my H22 acting like this?????????? WTF
Modified by BALLIN H22 EK at 12:38 AM 7/19/2006
Old Mar 27, 2006 | 04:13 PM
mgags7's Avatar
you hooked something up wrong, check the wiring....
do you have a check engine light on??
also, does that 190 cylinder happen to be the one with the bad sparkplug?
Old Mar 27, 2006 | 06:11 PM
safe driver's Avatar
exhaust leak?
Old Mar 27, 2006 | 07:25 PM
Default Re: why is my H22 acting like this?????????? WTF (BALLIN H22 EK)
helpump!!!!!!!!!!!
Old Mar 27, 2006 | 07:56 PM
TXcivic96's Avatar
hows the oil? take your hose that conects to the intake off and see if you have alot of blow by. Mine did the same thing and turned out to be a burned piston.
Old Mar 27, 2006 | 09:15 PM
Andyroo's Avatar
u sure the exhaust piping is bolted up tite?
Old Mar 28, 2006 | 04:49 AM
Default Re: (Andyroo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Andyroo &raquo;</TD></TR><TR><TD CLASS="quote">u sure the exhaust piping is bolted up tite?</TD></TR></TABLE>
yea its bolted up tight... i did notice some cracks in the header up top where it comes off the block tho...
Old Mar 28, 2006 | 04:53 AM
The Weather Man's Avatar
Maybe your valves are sticking.
Old Mar 28, 2006 | 05:22 AM
Default Re: (The Weather Man)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Weather Man &raquo;</TD></TR><TR><TD CLASS="quote">Maybe your valves are sticking.</TD></TR></TABLE>
lately ive been hearing a loud ticking coming from the valve cover/injectors.... dunno which one..
Old Mar 28, 2006 | 05:47 AM
TXcivic96's Avatar
Default Re: (BALLIN H22 EK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BALLIN H22 EK &raquo;</TD></TR><TR><TD CLASS="quote">
oil was just changed a week ago
what do i look for when i take the hose to the intake off? oil?</TD></TR></TABLE>
Blow by.
lately ive been hearing a loud ticking coming from the valve cover/injectors.... dunno which one..</TD></TR></TABLE>
Investigate this, how long has it been since you adjusted your valves?
Old Mar 28, 2006 | 08:09 AM
UK_Luder's Avatar
[QUOTE=BALLIN H22 EK]checked sparkplugs one was missing the porcilen so i replaced it and it still did the same QUOTE]
What if some of the broken porcilen fell into the combustion chamber?
Old Mar 28, 2006 | 08:28 AM
crdcz03's Avatar
Fortune Cookie Member
Default Re: why is my H22 acting like this?????????? WTF (UK_Luder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UK_Luder &raquo;</TD></TR><TR><TD CLASS="quote">[QUOTE=BALLIN H22 EK]checked sparkplugs one was missing the porcilen so i replaced it and it still did the same QUOTE]
What if some of the broken porcilen fell into the combustion chamber? </TD></TR></TABLE>
hmm... thats an interesting picture in my head
Old Mar 28, 2006 | 09:22 AM
SteveoBA8's Avatar
Default Re: why is my H22 acting like this?????????? WTF (crdcz03)
Pull your plugs out again and make sure one didnt crack.
Old Mar 28, 2006 | 11:20 AM
roller3804's Avatar
It would have most likely been tossed out the exhaust valves. But its a possibility. I have been working on this car with him for a while now...We
are going to check the injectors to make sure they are ticking, replace the plugs, and replace the oil seals for the spark plug cavity under the valve cover.
BALLIN H22 EK
Apr 7, 2006 02:41 PM
huge230
Oct 7, 2005 10:37 AM
eyesayuh
19
Jun 28, 2005 10:50 AM
95accordh22a
Dec 5, 2004 06:18 PM
xsellxoutx
Jul 18, 2004 04:24 PM
