70mm Throttle bodie from BDL ( STR )
Old Mar 27, 2006 | 11:03 AM
modifications's Avatar
Default 70mm Throttle bodie from BDL ( STR )
http://www.BDLind.com
has anyone fitted one of these, im looking to fit a 70mm BDL on my H22A7 with a AEM Cold AIR intake
would i benifit from it or are they a waste of money.
i will upgrading the valve train and cams very soon maybe some crower stage 2 maybe 3 and port and polish the head.
thanks
Old Mar 27, 2006 | 11:06 AM
Default Re: 70mm Throttle bodie from BDL (modifications)
sorry my motor is a Accord Type R ( UK )
Old Mar 27, 2006 | 12:30 PM
iakona's Avatar
i have one. you need to do some work to the port area of the I/M to get it to work though.
Old Mar 27, 2006 | 12:42 PM
Default Re: (iakona)
hi bud, what sort of work.
boring the I/M to match the throttle bodie
do they make any improvement on performance
Old Mar 27, 2006 | 12:46 PM
iakona's Avatar
you need to bore the manifold to match, and match your gasket (although the BDL should come with a gasket).
you will also need to make sure the water jackets and air passages you cut into are handled accordingly. the FITV isn't used on the new TB, so you don't have to worry about that, but there are other passages that need to match up.
and yes, it helps!! my H22 s-spec loved it, and my newest H23A VTEC, i don't think it could live without it. i have the 70mm, and it's great.
liljimmy14
Nov 28, 2010 10:12 AM
polishedturd
Jan 11, 2008 10:11 AM
SuperJay
Apr 18, 2005 07:03 PM
zilverz
Jun 23, 2002 12:58 PM
Mikey3000
May 28, 2002 04:06 AM
