bad tie rod bushing ?
Hi there. I have an 89 crx si and I am having some problems with the steering...
First of all, I have a bad bearing that I am about to replace. and I bought teins with agx's that I am about to replace stock suspension....
The problem that I have is that is easier to turn left than turning right.....
Maybe this is a bad tie rod ?..... I saw that the bushings were like warped, So I am planning on buying the energy suspension bushings for the tie rods......
Do you think this problem is caused by the tie rods ? or something else ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pakipr »</TD></TR><TR><TD CLASS="quote">will this help ?
NO dont get those!!, just get new tie rods they have the boot installed already, those just let dirt and gunk in and will let the joint wear out faster, it wont fix a bad joint, just get new ones
</TD></TR></TABLE>NO dont get those!!, just get new tie rods they have the boot installed already, those just let dirt and gunk in and will let the joint wear out faster, it wont fix a bad joint, just get new ones
Dylanamus
Mar 2, 2008 07:06 PM
Magick211
Oct 30, 2006 09:35 AM
