TW: Bense's D-series hybrid close ratio transmission (close ratios like a GSR but for d-series!)
Old Mar 27, 2006 | 08:35 AM
Bense's Avatar
Default TW: Bense's D-series hybrid close ratio transmission (close ratios like a GSR but for d-series!)
SOLD SOLD SOLD SOLD SOLD SOLD SOLD! for $580!
EDIT: more added below, I am offering a 5th gear option for this
I may be willing to sell this thing. The only reason that I am selling is because well, I have parts to build another one with a quaife LSD and a infinitude final drive.
This is a hydro transmission, it fits all 92-00 civics and all d-series engines.
1st = 3.25 (all d-series)
2nd = 1.9 (ex/si)
3rd = 1.346 (cable dohc zc tranny!)
4th = 1.033 crx hf 3rd as 4th
5th = 0.702 (dx/lx/hx/vx/ex/cx) 5th. (3400rpm @ 80) (I can put whatever 5th gear you want in here) But that will cost extra. I currently only have a 0.702 and a zc 5th. Got a 88-91 dx/ex tranny to pull 5th gear out of? 0.771 makes a nice 5th gear ratio. Math calculations below with the gearing differences.
ex final of 4.25
gears end at the following mph.
35, 60, 85, 111, 163 (0.702 5th)
As taken from my tranny page, this will show the closeness of the gears:
1.900 / 3.250 = 0.58466 or 58.466%
1.346 / 1.900 = 0.70842 or 70.842%
1.033 / 1.346 = 0.76746 or 76.746%
0.702 / 1.033 = 0.67957 or 67.957% (bigger gap between 4th and 5th because I chose to use a 0.702 5th for better highway rpm and gas mileage. It's not like I need to accelerate past 111mph anyways.)
In comparison, check out the rpm drops for the jdm itr 4.785 tranny!
2.105 / 3.230 = 0.65170 or 64.170%
1.458 / 2.105 = 0.69264 or 69.264%
1.034 / 1.458 = 0.70919 or 70.919%
0.787 / 1.034 = 0.76112 or 76.112%
You will see that my tranny has yet an even closer 2nd, 3rd and 4th gear than the jdm ITR!!!!
EDIT: $BEST OFFER And that's a steal. Mainly because I spent 200 dollars on a dohc zc tranny that I did nothing with except pull the 3rd gear out of. And about 15 hours of research figuring out how to do this.
This is the tranny that I talked about here.
https://honda-tech.com/zerothread?id=1449896
I personally know that you cannot build one for cheaper. Unless you buy parts from a theive/guy that desperately needs money that you lowball, etc.
LOTS OF TIME WENT INTO MAKING THIS THING. If you don't like the price, I welcome you to try to make one yourself. I even state how to do it on the above link. However I highly doubt that you can build this for any cheaper considering that hmotorsonline raised the price from 150 to 250 on these zc trannys (which they never have any in stock)
Gearbox:- Bense's Hybrid tranny with 0.702 5th
Tyre:- Michelin all patterns 185/65 x 14
Top Gear gives 22.683 MPH/1000 RPM and a top speed of 167.855 MPH at 7400 RPM
Engine speeds in top gear:-
30 MPH = 1323 RPM 40 MPH = 1763 RPM 50 MPH = 2204 RPM 60 MPH = 2645 RPM
70 MPH = 3086 RPM 80 MPH = 3527 RPM 90 MPH = 3968 RPM 100 MPH = 4409 RPM
Top Speed in 1 gear = 36.257 MPH
And changes into 2 gear at 4326 RPM dropping 3074 RPM
Top Speed in 2 gear = 62.018 MPH
And changes into 3 gear at 5242 RPM dropping 2158 RPM
Top Speed in 3 gear = 87.544 MPH
And changes into 4 gear at 5679 RPM dropping 1721 RPM
Top Speed in 4 gear = 114.070 MPH
And changes into 5 gear at 5029 RPM dropping 2371 RPM
Top Speed in 5 gear = 167.855 MPH
Gearbox:- Bense's Hybrid tranny with 0.750 5th
Top Gear gives 21.231 MPH/1000 RPM and a top speed of 157.113 MPH at 7400 RPM
30 MPH = 1413 RPM 40 MPH = 1884 RPM 50 MPH = 2355 RPM 60 MPH = 2826 RPM
70 MPH = 3297 RPM 80 MPH = 3768 RPM 90 MPH = 4239 RPM 100 MPH = 4710 RPM
And changes into 5 gear at 5373 RPM dropping 2027 RPM
Top Speed in 5 gear = 157.113 MPH
Gearbox:- Bense's Hybrid tranny with 0.771 5th
Top Gear gives 20.653 MPH/1000 RPM and a top speed of 152.833 MPH at 7400 RPM
30 MPH = 1453 RPM 40 MPH = 1937 RPM 50 MPH = 2421 RPM 60 MPH = 2905 RPM
70 MPH = 3389 RPM 80 MPH = 3874 RPM 90 MPH = 4358 RPM 100 MPH = 4842 RPM
And changes into 5 gear at 5523 RPM dropping 1877 RPM
Top Speed in 5 gear = 152.833 MPH
Gearbox:- Bense's Hybrid tranny with 0.878 5th
Top Gear gives 18.136 MPH/1000 RPM and a top speed of 134.208 MPH at 7400 RPM
30 MPH = 1654 RPM 40 MPH = 2206 RPM 50 MPH = 2757 RPM 60 MPH = 3308 RPM
70 MPH = 3860 RPM 80 MPH = 4411 RPM 90 MPH = 4962 RPM 100 MPH = 5514 RPM
And changes into 5 gear at 6290 RPM dropping 1110 RPM
Top Speed in 5 gear = 134.208 MPH
Modified by Bense at 5:58 PM 3/27/2006
Modified by Bense at 6:23 PM 3/27/2006
EDIT: I have already received 6 offers for this thing. And so far the highest bid is $550 shipped. I currently have a 0.750 5th gear in it, but I was planning on keeping it and putting a more common 0.702 5th gear in it. (which most would prefer the longer 5th gear for lower cruising rpms anyways) if for some reason you still want the 0.750 del sol si 5th gear instead of the 0.702, there will be an extra charge for this. The same goes with the 0.878 zc 5th gear. This raises the highway rpms to an equivalent of stock b16 5th gearing
stock b16 5th gearing = 4.4 (final drive) * (0.848) 5th gear = 3.7312
zc 5th with ex final = 4.25 (final drive) * (0.878) 5th gear = 3.7315
there are many advantages / disadvantages to whatever 5th gear that you choose. If you are unsure of which to choose from, feel free to PM me asking which. There also is the 88-91 dx/si 5th gear option of 0.771. However I don't have one of these 5th gear sets. If you have one that you'd like to mail me I will put it in at no additional cost. However the dx/si 5th gear is only 2.8% different from the 0.750 del sol si / hatchback si 5th gear. The graph shows all 4 gear options.
Note, some may mention the tall 0.694 crx hf 5th gear. But remember there is only a 0.008 difference in the 0.694 hf 5th gear and the 0.702 5th gear. That comes out to be a 1.1% difference. like 35-40rpm difference when at 80mph. This is not worth it being the difference is so minute. The only advantage that it would have is bragging rights. And even with that said the stock tach isn't acurate enough to show the difference, so you could use the 0.702 5th gear and lie about having a crx hf 5th gear and only you and me would ever know!!
I know that this is a lot of info. But as you can see I know what I am doing here and you should know exactly what goes into the transmission that you may be interesting in purchasing.
Modified by Bense at 1:48 PM 3/28/2006
Modified by Bense at 4:26 PM 3/28/2006
Modified by Bense at 8:18 PM 3/28/2006
Old Mar 27, 2006 | 10:46 AM
Laserjock's Avatar
Default Re: TW: Bense's D-series hybrid close ratio transmission (Bense)
bump cause i looked.
any trades? i have a 92-95 EX tranny or anything in my sig
Old Mar 27, 2006 | 11:27 AM
Bense's Avatar
Default Re: TW: Bense's D-series hybrid close ratio transmission (Laserjock)
only thing I may be looking for is a used d-series jsrc, (tranny + cash)
jdm d15b shortblock (well all I really need is the crank)
d-series quaife lsd (like anyone has one)
and that's about it
I already have like 9 transmissions that I'm trying to get rid of
but thanks for the bump
Old Mar 27, 2006 | 02:02 PM
Bense's Avatar
bump because I added more technical data to convince you guys to buy it
Old Mar 27, 2006 | 02:05 PM
posite's Avatar
bump.. looks like you definetly know what you are doing!
Old Mar 28, 2006 | 06:11 AM
Bense's Avatar
Default Re: (posite)
sale pending
Old Mar 28, 2006 | 06:48 AM
zeroice's Avatar
thats crazy...
Old Mar 28, 2006 | 08:40 AM
Bense's Avatar
Default Re: TW: Bense's D-series hybrid close ratio transmission (zeroice)
okay I have already received several guys offering me money. I hate to do this, But whoever offers me the most...
Old Mar 28, 2006 | 09:10 AM
the jdmchop's Avatar
made my offer!
Old Mar 28, 2006 | 09:48 AM
Bense's Avatar
Default Re: TW: Bense's D-series hybrid close ratio transmission (jdmchop)
edited the first post some.
Old Mar 28, 2006 | 04:56 PM
Bense's Avatar
SOLD SOLD SOLD!!! FOR 580!
Red_ED8
Mar 20, 2010 10:02 AM
1gencrx
Jan 13, 2010 10:28 AM
chivid
Transmission & Drivetrain
10
Feb 19, 2009 07:09 PM
Bense
Mar 28, 2006 09:50 AM
foxbody5l
Aug 17, 2005 10:21 AM
