Carbon creations hood
Old Mar 27, 2006 | 07:53 AM
h22vt's Avatar
Default Carbon creations hood
So i got my new hood in this morning. I put it on and its horrible!!!!!!! the quality it good, but the fit sucks! what should i do? how hard is it to install hood pins?
ps. the green strobe lights were in there when i got the car! not mine!!!!! havent had time to take them out!!
also what can i do to fix my headlights?
Old Mar 27, 2006 | 08:07 AM
Vtecattack's Avatar
I would demand a refund if I were you.
Doesnt look like it was even for you car.
Thanks for the warning
Old Mar 27, 2006 | 08:11 AM
h22vt's Avatar
Default Re: (Vtecattack)
im so sad i just wanna cry!!!!! someone help me!!
would cf fyflids help any IF i HAVE to keep it?
Old Mar 27, 2006 | 08:21 AM
98vtec's Avatar
moderator emeritus
Default Re: (h22vt)
have you done any aligning with the hood mounts? Try that before you get all huffy puffy.
Old Mar 27, 2006 | 08:29 AM
h22vt's Avatar
nope sure havent!! lol what do you mean?
Old Mar 27, 2006 | 08:34 AM
98vtec's Avatar
moderator emeritus
Default Re: (h22vt)
pop your hood and look at the mounts that hold the hood to the car. You will see that you can make small adjustments on the mounts. Loosen the bolts and see what you can do to make it fit right.
Old Mar 27, 2006 | 08:39 AM
h22vt's Avatar
the bolts on the hood or the car? as far as i can tell if i move it to fit my headlights it wont fit at the other end.
Old Mar 27, 2006 | 08:40 AM
The_Sober's Avatar
Default Re: (98vtec)
to fix your headlights, get a bottle of polishing compound from an auto parts store and have at it.
Old Mar 27, 2006 | 08:41 AM
98vtec's Avatar
moderator emeritus
Default Re: (h22vt)
bolts on the hood
Old Mar 27, 2006 | 08:43 AM
jdmwestcoaststyle's Avatar
no no no no...lol... i Carb Creations sucks at fitment. and takes alot to make it work and look somwhat decent. believe me i bought a hood and trunk lid from them for my accord. the hood took some work and still fits a litle high ( with out hood pins it looks a little open) and hte trunk lid is just not fluch with my tail lights ( like if it needs hood pins but for the trunk) ... i tried to get my money back but if you read thier site.. it striclty indicates that these parts are not oem fitment and may require some modification..half the **** they sell is carbon grade A. but fitment grade is C.. meanin there are minor imperfections that can be fixed with modifications.. good luck , but next time go with VIS.
Old Mar 27, 2006 | 08:44 AM
h22vt's Avatar
Default Re: (The_Sober)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The_Sober &raquo;</TD></TR><TR><TD CLASS="quote">to fix your headlights, get a bottle of polishing compound from an auto parts store and have at it.</TD></TR></TABLE>
Thanks!!!
I dont think those bolts will fix it.
Old Mar 27, 2006 | 08:45 AM
h22vt's Avatar
Default Re: (jdmwestcoaststyle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmwestcoaststyle &raquo;</TD></TR><TR><TD CLASS="quote">no no no no...lol... i Carb Creations sucks at fitment. and takes alot to make it work and look somwhat decent. believe me i bought a hood and trunk lid from them for my accord. the hood took some work and still fits a litle high ( with out hood pins it looks a little open) and hte trunk lid is just not fluch with my tail lights ( like if it needs hood pins but for the trunk) ... i tried to get my money back but if you read thier site.. it striclty indicates that these parts are not oem fitment and may require some modification..half the **** they sell is carbon grade A. but fitment grade is C.. meanin there are minor imperfections that can be fixed with modifications.. good luck , but next time go with VIS.</TD></TR></TABLE>
where were you 2 weeks ago when i was asking about carbon creations!!!!! lol!!!
Old Mar 27, 2006 | 10:04 AM
mgags7's Avatar
just get a set of hoodpins, theyre a good idea anyways....
also check the rubber bumpstops on the radiator support, they screw in and out some....
Old Mar 27, 2006 | 10:08 AM
bigj505's Avatar
Default Re: (mgags7)
try installing the rubber gaskets that were on your oem hood. you know, the ones that lined your headlights. could possibly close the gap...
Old Mar 27, 2006 | 10:54 AM
honda3431's Avatar
Default Re: (h22vt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22vt &raquo;</TD></TR><TR><TD CLASS="quote">
where were you 2 weeks ago when i was asking about carbon creations!!!!! lol!!! </TD></TR></TABLE>
If you were that guy, there were plenty of people that told you to go with ViS (including me). You just didn't listen to us because the people who didn't take care if their ViS complained about its quality. ViS isn't the best out there, but it looks a hell alot better than that. Sorry about your crappy hood man.
Old Mar 27, 2006 | 11:36 AM
illdiealonlyazn's Avatar
Default Re: Carbon creations hood (h22vt)
you know to be totally honest, it really does look like the gap just big enough for the rubber peices that were attached to your st ock hood.The rubber peice that closes the gap btwn your stock hood and your headlights. If you were to take off the rubber peice on your stock hood it would have the same gap, i saw it on another prelude. Try that out and see if it works.
Old Mar 27, 2006 | 11:37 AM
h22vt's Avatar
i had a VIS hood on there before, it sucked. but at least it fit!! kinda ironic huh!! lol we'll see what happens ill let you know!! SEIBON from now on!!!
Old Mar 27, 2006 | 11:57 AM
wstef's Avatar
Don't cry, just install the OEM rubbers, it was the case of my friend.
It changes everything:
Old Mar 27, 2006 | 12:59 PM
IIVIIoOkY's Avatar
Default Re: Carbon creations hood (wstef)
Did it suck as in it faded or what? the vis hood you had you said fit perfectly and according to everyone else as long as you take care of it, it will last you a good 4 years im sure thats the case with any cf hood.
Old Mar 27, 2006 | 01:15 PM
Sabbotage's Avatar
I looks like you may be able to loosen the hood latch and slide it down some too along with installing the OEM rubber around the headlights. I had to do that with my hood on my 4th gen to get it to close the gap between the hood and bumper.
JSP FTW!
BEAT_UP_EK
Jan 10, 2010 05:19 PM
scabbs
Sep 17, 2007 06:48 PM
da9blk1
Sep 10, 2007 09:46 AM
skud_dusty
Mar 12, 2003 10:29 AM
shingles
13
Mar 13, 2002 01:23 PM
