JUST BUILT TURBO MOTOR N NOW LEAKING OIL AND SHOOTING SMOKE
Old Mar 27, 2006 | 07:40 AM
NosCivic01's Avatar
Default JUST BUILT TURBO MOTOR N NOW LEAKING OIL AND SHOOTING SMOKE
i just built a gsr motor n put it in. the motor runs fine except for 2 things.
1st thing is that its leakin oil from somewhere n it seems to b coming down the flywheel cover. i havent put it on my lift yet at my job so that could b something small. but its def coming from the back of the motor? any suggestions.
2nd thing is smoke is coming thru the little air breather on the valve cover. realy pressurized too. if i hold my finger over it for 5 sec. the pressure builds up n wen i let go it shoots out like a gun n wistles. and then white smoke comes out my exhaust n then goes away...wat is that????
please help if anyone can.
Old Mar 27, 2006 | 07:46 AM
Jay.D.Em!'s Avatar
Default Re: JUST BUILT TURBO MOTOR N NOW LEAKING OIL AND SHOOTING SMOKE (NosCivic01)
all i can say about your oil leak is check the threads where the sending unit screws in.. ive had that problem before..
Old Mar 27, 2006 | 10:05 AM
NosCivic01's Avatar
Default Re: JUST BUILT TURBO MOTOR N NOW LEAKING OIL AND SHOOTING SMOKE (Saved_Sol)
thats tru..anyone know about the air breather and the pressurized smoke? never seen that before????
Old Mar 27, 2006 | 10:06 AM
NosCivic01's Avatar
wat sending unit screw are u talking about??
Old Mar 27, 2006 | 10:24 AM
stockredej1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NosCivic01 &raquo;</TD></TR><TR><TD CLASS="quote">thats tru..anyone know about the air breather and the pressurized smoke? never seen that before????</TD></TR></TABLE>
That happended to my motor, it was Bad piston rings
Old Mar 27, 2006 | 10:51 AM
NosCivic01's Avatar
Default Re: JUST BUILT TURBO MOTOR N NOW LEAKING OIL AND SHOOTING SMOKE (stockredej1)
damm that sux. i jus put the motor in the car 2. brand new pistons n ****.
Old Mar 27, 2006 | 10:54 AM
MitchH's Avatar
Man I hope you figure it out. I know what it's like to have mystery probs.
Old Mar 29, 2006 | 02:41 PM
dkboyny11's Avatar
I've got smoke coming out of my valve cover to. I also have oil leaking through the turbo and into the charge pipes. It is also shooting a lot of oil out of the blow-off valve. I'm trying to get rid of the black box and add ventilation for the crankcase in hopes that it's not the motor.
Old Mar 29, 2006 | 02:51 PM
LSRracing95's Avatar
valve seals.
Old Mar 29, 2006 | 03:23 PM
integra3586's Avatar
1st thing is that its leakin oil from somewhere n it seems to b coming down the flywheel cover. </TD></TR></TABLE>
its most likley the rear main seal. chances are you didnt put the seal in correctly. probably not square or the lip got caught when you were installing it. possibly not enough lube on the crank
i had to re-do my rear main 3 times before i got it right. i guess i just suck at putting seals in.
Old Oct 5, 2008 | 02:19 AM
swappyturbo's Avatar
Default Re: JUST BUILT TURBO MOTOR N NOW LEAKING OIL AND SHOOTING SMOKE (integra3586)
one of my friends had same problem, smoke out of breather, ended up being cracked piston...as one of the RC injectors wasnt flowing right
but yeah i hope it isnt the case for you...wish you the best of luck
rear crank seal...is a painnnnnnn....
I never knew there was a correct way to fitting them...always used to get them flush and leave it...but helms says otherwise..like to take of the retainer with oil seal still in...to measure gap from seal to retainer with feeler gauge...and refit new seal with same gap and flush..
beamer
Jul 29, 2015 03:21 PM
deary09
Oct 12, 2011 06:06 AM
kikwear002
Jan 24, 2005 06:09 PM
Fbp00si
Jul 25, 2003 01:49 PM
sivic_si
Dec 4, 2002 02:45 PM
