my car sucks
Old Apr 3, 2002 | 10:17 AM
illusion's Avatar
Default my car sucks
https://honda-tech.com/zerothread?id=154729
its probably the alternator.. but im fed up with getting stuck places. im about to sell this **** and buy a 240sx.
Old Apr 3, 2002 | 10:44 AM
Honda318dx's Avatar
Default Re: my car sucks (illusion)
your bad alternator killed your battery, so both are dead, some of the answers people gave you about fuses and such are just
Old Apr 3, 2002 | 11:08 AM
bgod's Avatar
Default Re: my car sucks (Honda318dx)
don't be so upset with the car. if it is the alternator it's a common replacement part. when is the last time you changed it?
if you haven't changed it since you've owned the car the owner before you probably didn't either. easily replaced.
i posted to the above topic.
i had the same symptoms as you and it was my battery terminals. exactly as you described.
but to me it sounds like your alternator is definitely out. once you put a new battery in, it will kill it very soon.
and yes, while the car is at idle, if you pull the negative battery terminal and the car dies. it's a tell-tale sign of needing a new alternator. if the car doesn't die, you probably have another problem.
remember, your car is still a 94. it requires more maintenance then say a 97-up prelude.
mytest23
24
May 6, 2015 07:29 AM
Wiretaju
Jun 25, 2010 03:02 PM
Fatty_1775
Oct 23, 2002 02:33 AM
Martaigne
Jul 14, 2002 04:19 PM
