Crank Pulley Removal - Special Tool?
Old Mar 27, 2006 | 03:55 AM
MyRex's Avatar
Default Crank Pulley Removal - Special Tool?
Quick general question about getting the crank pulley off. I have a '92 Integra LS DOHC.
I'm in the middle of changing the timing belt, only thing is CAN NOT get the crank pulley nut off!! I have an impact gun that is running at about 180lbs and it can't quite break it loose. In the pulley there is hexagon cut out around the the nut. It's got to be some kind of Acura factory tool to stick in there to hold the pulley from moving so you can get the nut off. The hexagon measures 2" flat-to-flat.
My question is, does anyone know if a tool like exists (what is it called?), and if so, where can I get one? Acura Dealership only?
Thanks Everyone!
Old Mar 27, 2006 | 04:49 AM
96BlackHB's Avatar
Default Re: Crank Pulley Removal - Special Tool? (MyRex)
Yes, there is a tool to hold the pulley:
Moroso makes one:
http://www.moroso.com/catalog/...27115
Also here:
http://www.autopart.com/TOOLS/...2.htm
And here:
http://www.etoolcart.com/index...=7869
Several on here:
http://www.etoolcart.com/brows....html
from $25-$110
Old Mar 27, 2006 | 04:57 AM
MyRex's Avatar
Default Re: Crank Pulley Removal - Special Tool? (96BlackHB)
GREAT! Thank You!
Old Mar 27, 2006 | 05:25 AM
The Destroyer's Avatar
I put the car in gear when I bust the CP off with an impact gun.
Old Mar 27, 2006 | 05:31 AM
Sam92Teg's Avatar
Default Re: Crank Pulley Removal - Special Tool? (Vtaaak y0)
I just did my timing belt, tensionor, and water pump. I took my car to a local garage and had them loosen the crank pulley bolt and then retighten it. When I got home, I used my two breaker bars and the $25 tool bought from Amizon.com and it was a breeze to remove the crank pulley bolt. The water pump itself was harder to remove than the crank pulley. Good luck.
Old Mar 28, 2006 | 05:54 PM
jdmsiR20's Avatar
Default Re: Crank Pulley Removal - Special Tool? (Sam92Teg)
http://www.amazon.com/gp/produ...28013
worked great for me
Tims Toy 500
Honda CR-V & Element
Mar 15, 2011 05:49 AM
Spawne32
Aug 18, 2010 08:09 PM
B!^A@
Nov 21, 2006 10:04 AM
david90
Aug 15, 2003 01:15 PM
Tommy_Gunns
Jul 18, 2002 06:14 AM
