Acura TL, RL & ZDX Includes Legend, Vigor and 2001 - 2003 Acura CL
motor swap for a 98 2.3 cl
Old Mar 27, 2006 | 12:38 AM
CLman1313's Avatar
Default motor swap for a 98 2.3 cl
What would be the best motor for a swap? Ive got a 98 2.3 cl ive thought about a h22 or maby the 3.2 out of the newer cl. What would be best?
Old Mar 27, 2006 | 05:33 AM
CmptchAV6's Avatar
Default Re: motor swap for a 98 2.3 cl (CLman1313)
probably the h22 the j30 or the j32 would take much more money to accomplish because of mount differences
Old Mar 27, 2006 | 06:08 AM
CLman1313's Avatar
Default Re: motor swap for a 98 2.3 cl (CmptchAV6)
thats kinda what i was thinking to but if i did use the j32 how much do you think it would cost? What about a a f20b?
Old Mar 27, 2006 | 07:22 AM
CmptchAV6's Avatar
any f/h series motor should be a direct bolt in since you already have an f series motor in your car. As for the J series you would most likely have to get the engine support sub frame from the 3.0cl plus the mounts which are expensive because the jseries uses liquid filled mounts, plus the manual trannies for these cars are still relativly hard to find as they havent produced a whole lot of them and the autos arnt worth it imo. I would say for the price of putting in a j32 you could probably get the h22 close if not exceeding that power output for the same amount of money, plus the h22 has much more room to expand because of the greater aftermarket
Old Mar 27, 2006 | 08:29 PM
CLman1313's Avatar
Thanks for the help Im going to go with the h22 like you said it would be cheaper.
Old Mar 27, 2006 | 08:34 PM
CLman1313's Avatar
Will the tranny in my f23 bolt up to the h22?
Old Mar 28, 2006 | 08:30 AM
CmptchAV6's Avatar
yes it will. As for further info about h and f series conversion I would go to the Accord forum and search around after all all a cl is is a accord with slightly different external styling
Old Mar 28, 2006 | 06:58 PM
CLman1313's Avatar
what would you recomend boost or ^compression and do all motor?
Old Mar 29, 2006 | 09:00 AM
CmptchAV6's Avatar
boost would probably be the cheapest way to get lots more power. When you do it though you will want to have it tuned that way you are running more efficiently and you know no engine detrimental instances are happening such as detonation
Old Mar 29, 2006 | 08:51 PM
CLman1313's Avatar
How much do you think it might cost to build the motor for around 18 pounds of boost well what would you recomend for the amount of boost? Dont you have to get it sleeved when you put new pistens in it? Bear with me im kinda new at this turbo stuff i dont no much about it.
Thanks
Old Mar 30, 2006 | 09:01 PM
CmptchAV6's Avatar
I havent personally built a high performance turbio motor so your best bet would be to start searching through the FI forum on this board for better info than I can provide
Old Mar 31, 2006 | 04:58 AM
CLman1313's Avatar
Ok thanks for all of the help
Old Apr 1, 2006 | 06:14 PM
Blazin Si's Avatar
Loved
Community Favorite
Check http://cl.acurazine.com/forums/
That's the best forums for 1st gen CL's. There's a bunch of H22 swapped CL's on there and even one guy that's swapping in a J32.
mjutila
Jan 7, 2012 09:20 AM
Pariah
May 10, 2004 06:42 PM
EGsex
Sep 13, 2002 11:01 AM
R-gonaut
Aug 1, 2002 01:59 AM
