gauge cluster lights dont turn on
i was driving then all of a sudden my gauge cluster lights dont work. also the ac/heater unit lights dont work ether. but the gauge cluster it self works. just not the lights. i also checked all the fueses under the steering wheel and under the hood. they are all good. also checked dimmer switch too. no luck.
Modified by roterx7 at 12:06 PM 3/27/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRR 2 »</TD></TR><TR><TD CLASS="quote">just had that happen to me had to put new dimmer switch in </TD></TR></TABLE> most likely,
pull the dimmer out and check if power is going in but not coming out
My first thought is that it is your dimmer switch. I assume you know where that is. If you know someone with a simular car, Try theirs and see if it works or go to a junk yard and pay $2 for a used one. I'm 99% sure you need to replace the dimmer switch.
Antonio_P.R
Oct 21, 2008 09:52 AM
Jay.D.Em!
Apr 17, 2006 07:17 PM
