any difference between GSR and ITR rods?
Old Mar 26, 2006 | 09:57 PM
92integraVTECgsr's Avatar
Default any difference between GSR and ITR rods?
Old Mar 26, 2006 | 10:25 PM
super_nguyen's Avatar
Default Re: any difference between GSR and ITR rods? (92integraVTECgsr)
nope none at all
Old Mar 26, 2006 | 10:26 PM
Default Re: any difference between GSR and ITR rods? (super_nguyen)
the only difference is if you mean the 92-93 gs-r's the rods are shorter for the b17, but for the DC integra's gsr's have the same rods as type r's
Old Mar 26, 2006 | 10:53 PM
thanks
Old Mar 26, 2006 | 11:46 PM
b19coupe's Avatar
ITR rod-13210-P73-000
GSR rod-13210-P72-000
There is a difference-but you can use either in a B18C.
Old Mar 27, 2006 | 12:34 AM
StorminMatt's Avatar
Default Re: any difference between GSR and ITR rods? (b19coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote">ITR rod-13210-P73-000
There is a difference-but you can use either in a B18C.</TD></TR></TABLE>
But is the difference real?
Old Mar 27, 2006 | 05:11 AM
spoonek9's Avatar
Default Re: any difference between GSR and ITR rods? (StorminMatt)
ITR rods are supposed to have a higher chromoly content.
Old Mar 27, 2006 | 06:03 AM
b19coupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StorminMatt &raquo;</TD></TR><TR><TD CLASS="quote">
But is the difference real?</TD></TR></TABLE>
Type-R rods have"R" stamped on them, so they must be better
Old Mar 27, 2006 | 08:02 AM
IN VTEC's Avatar
ITR rods use a different big-end numbering system (22 to 25 instead of 1 to 4). The rod fasteners are the primary difference tho. The regular P72 rod fasteners don't have the dimples on the ends for a stretch gauge.
The masses are very comparable. The range of mass is from 544g to 553g. However, the rods are typically around 545g to 547g in the matched sets I've sampled.
I'm also inclined to say that the ITR rods' big-ends are finished to a larger bore, but I've never had a chance to sample a large number of both types of rods. My basis is that there's an extra step on the number system (5 for ITR vs. 4 for GS-R), and that the ITR's are spec'd to run .0002" looser on the rod oil clearances.
Old Mar 27, 2006 | 09:47 AM
Baggy Spandex's Avatar
Default Re: any difference between GSR and ITR rods? (IN VTEC)
"Connecting Rod Summary:
* Connecting rod bolt elongation has been strictly controlled for uniform fastening force
* Manually assembled for the Type R to reduce fastening force variance
* The specially designed rods have the letter "R" molded onto them
* Rods are constructed of special high-strength steel to withstand higher rpm's and are still lighter than GS-R connecting rods "
Old Mar 27, 2006 | 10:33 AM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: any difference between GSR and ITR rods? (NAisBEST)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAisBEST &raquo;</TD></TR><TR><TD CLASS="quote">"Connecting Rod Summary:
* Rods are constructed of special high-strength steel to withstand higher rpm's and are still lighter than GS-R connecting rods "</TD></TR></TABLE>
Vinny, showing up with some knowledge.
Old Mar 27, 2006 | 11:33 AM
Default Re: any difference between GSR and ITR rods? (mar778c)
haha you know it!
pretty cool link i found about the ITR.
http://www.itrsport.com/technical
oneslowstd
Nov 11, 2007 05:28 PM
Chillinit
Sep 28, 2004 07:51 AM
SioneSi
Aug 5, 2004 04:22 PM
DragInteg
May 3, 2004 05:42 AM
ScottFern
Jul 11, 2003 06:44 AM
