Gap between Upper Exhaust manifold and lower manifold leaking air
Old Mar 26, 2006 | 06:17 PM
xunkn0vvnx's Avatar
Default Gap between Upper Exhaust manifold and lower manifold leaking air
I have a stock 00 type R header. I changed my oil pan today and therefore had to remove the lower exhaust header to get to the pan. I assembled the header as normal when finished, and when i started my car it sounded noticeably louder. The intersection of where the upper exhaust header meets the lower exhaust header is leaking air. I torqued down all the bolts as tight as I could and it still made noise. I drove the car around and let the metal expand hoping the two components would bond. It worked somewhat, and I no longer feel exhaust air leaking. My question is whether I am going to run into this problem again in the future. Is there a gasket I could purchase or something to bond the two pieces together better ??
Old Mar 27, 2006 | 05:03 AM
ITR-00-1457's Avatar
Default Re: Gap between Upper Exhaust manifold and lower manifold leaking air (JeFFFFFFFrey91)
Yeah, there is a gasket that is supposed to go there.
-HONDA-
Dec 22, 2006 10:28 PM
skata89
Apr 29, 2006 04:36 PM
stiness101
Jan 11, 2006 10:12 AM
sleepinbeauTEG
Aug 4, 2004 07:25 AM
MOTOR R
Nov 26, 2001 10:10 AM
