OK to run 81mm head gasket on 84.5mm block?
Old Mar 26, 2006 | 06:16 PM
RTW DC2R's Avatar
Default OK to run 81mm head gasket on 84.5mm block?
Spoke to someone today who is actually doing this on a turbo setup. I was under the impression you HAD to run a gasket the size of the cylinders, not the size of the head chambers. I would think with gasket material open in the combustion chamber that it could cause problems with hot spots or ruin the gasket all together. Any thoughts?
Old Mar 26, 2006 | 07:47 PM
warwagon's Avatar
Default Re: OK to run 81mm head gasket on 84.5mm block? (RTW DC2R)
yeah i agree... that gasket is asking for failure
Old Mar 26, 2006 | 08:01 PM
Mythias's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2R &raquo;</TD></TR><TR><TD CLASS="quote"> I was under the impression you HAD to run a gasket the size of the cylinders ... Any thoughts?</TD></TR></TABLE>
You summed it up right there.
Old Mar 26, 2006 | 09:07 PM
white rocket's Avatar
Default Re: OK to run 81mm head gasket on 84.5mm block? (Mythias)
Hmmmmm....sounds kinda weird. Wouldn't the HG overlap the chambers?
Old Mar 26, 2006 | 10:29 PM
itr1244's Avatar
why not run 84.5 mm gasket?
i would anyways
Old Mar 27, 2006 | 05:07 AM
ITR-00-1457's Avatar
Default Re: OK to run 81mm head gasket on 84.5mm block? (itr1244)
Yeah, this will definately cause a problem
Old Mar 27, 2006 | 11:17 AM
Big Phat R's Avatar
Build your motor half-assed and it won't last.
- Johnny Cochrane (RIP)
Bc3
Dec 15, 2006 08:35 AM
byohnd
Nov 14, 2005 08:07 AM
jt-sport
11
Feb 11, 2004 02:57 PM
Crazy DA
Sep 21, 2001 12:08 PM
