need a picture of emergency brake switch
i took out my interior and am trying to put it back together. i can't figure out how to put together the switch that lights up the dash when the e-brake is on. could someone take a pic of their assemble or even a diagram.
Thanks
Thanks
ok, the wire has a flat piece of metal with a hole through it. does this go on the bottom of the bracket? under it or on top of it?
i can't figure out the mechanics behind how that would work though. like how pushing down on it would close any type of circuit
Damn, ok. Hook it up so that the e brake handle pushes down on the switch when it is lifted. In the picture, you see that tab sticking out the side of the base of the handle? That's what hits the switch. It mounts exactly as shown. A circuit is closed when you lift the handle because it connects the single wire to ground. Real easy. How bad is the situation in your car anyways??!!
babybreese
Aug 16, 2017 12:33 PM
crazyjetsfan22
Jul 20, 2011 03:34 PM
