zc motor help
Old Mar 26, 2006 | 12:12 PM
StraightCivic's Avatar
Default zc motor help
my friend has a zc motor in his 89 hatch and his car wont start. Its throwing a code 7 on the ecu. What would that code be? it blink 7 times and then blinks 2 times real fast
Old Mar 26, 2006 | 01:21 PM
DoHcZC91si's Avatar
Default Re: zc motor help (StraightCivic)
go search...very easy to find wat a code is here..
Old Mar 26, 2006 | 02:38 PM
hatchinprogress's Avatar
Default Re: zc motor help (DoHcZC91si)
heres a link so you can see for yourself what codes you got https://honda-tech.com/zerothread?id=468260
Old Mar 26, 2006 | 09:16 PM
boostedblkef's Avatar
Default Re: zc motor help (hatchinprogress)
sounds like you got a bad ca sensor i had same problem i got one working if you need
Old Mar 27, 2006 | 05:16 PM
Default Re: zc motor help (pitbullracer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pitbullracer &raquo;</TD></TR><TR><TD CLASS="quote">sounds like you got a bad ca sensor i had same problem i got one working if you need</TD></TR></TABLE> sorry i didnt check the codes...but if it's the crank angle sensor...i do have an extra 1 (i know it's a shameless plug )
Old Mar 27, 2006 | 05:58 PM
Autoworks's Avatar
7 is TPS
h22_crx
Oct 12, 2005 11:56 AM
drewboy
May 12, 2005 02:58 PM
EF'n
Sep 16, 2002 07:19 PM
FBPninetynineEM1
Jul 26, 2002 06:32 AM
crxgurlllll
13
Feb 12, 2002 07:11 AM
