Lubricating Window Tracks
Old Mar 26, 2006 | 10:38 AM
satintegra's Avatar
Default Lubricating Window Tracks
i notice that my windows do not roll down smoothly anymore, especially when it's cold. what kind of grease do you use to lube the window tracks?
Old Mar 26, 2006 | 10:46 AM
4U2NV's Avatar
Default Re: Lubricating Window Tracks (satintegra)
Use a silicon spray...
Old Mar 26, 2006 | 11:22 AM
mike9571's Avatar
Default Re: Lubricating Window Tracks (4U2NV)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4U2NV &raquo;</TD></TR><TR><TD CLASS="quote">Use a silicon spray... </TD></TR></TABLE>
what do you do just take of the door panel and spay it on the tracks?
Old Mar 26, 2006 | 11:24 AM
E-Money's Avatar
Default Re: Lubricating Window Tracks (mike9571)
bump, i would like to know as well..
Old Mar 26, 2006 | 04:25 PM
Promina's Avatar
Default Re: Lubricating Window Tracks (E-Money)
bump... me too...
Old Mar 26, 2006 | 04:27 PM
ck123's Avatar
a freind told me this..
get a bottle of windex and spray the sides of the door where the window slides down.Spray each side a few times and then roll your windows up and down a fill times also. After that spray both sides again but with hot water.
He says its slow because of dirt build up.
Old Mar 26, 2006 | 09:54 PM
satintegra's Avatar
Default Re: (ck123)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ck123 &raquo;</TD></TR><TR><TD CLASS="quote">a freind told me this..
He says its slow because of dirt build up. </TD></TR></TABLE>
don't you have to put something back on it to lube it up?
Old Mar 26, 2006 | 10:26 PM
07ssmfit916's Avatar
Default Re: (satintegra)
this article at team integra might help..
http://www.team-integra.net/se...D=596
Old Mar 27, 2006 | 01:51 PM
ck123's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike9571 &raquo;</TD></TR><TR><TD CLASS="quote">what do you do just take of the door panel and spay it on the tracks?</TD></TR></TABLE>
nope
Old Jul 18, 2006 | 04:23 PM
HGZ's Avatar
HGZ
Default Re: (00mrteg916)
back from the dead.. sorta..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00mrteg916 &raquo;</TD></TR><TR><TD CLASS="quote">this article at team integra might help..
http://www.team-integra.net/se...D=596</TD></TR></TABLE>
my window almost gets 'stuck' about half way when im rolling it down. it will struggle for a bit, then after a couple more inches, it will resume normal roll down speed. i looked at ^this article and it seems like it might improve my situation, but i have a question.. the article says to use air tool/compressor lube. but where? do i just squirt it directly into the rubber tracks??
Old Jul 18, 2006 | 04:47 PM
drift4jesus's Avatar
Default Re: (HGZ.)
Well that is where its sticking isn't it.... silicone spray saved my 160k mile old 94 gsr's windows. I'll have to give my pb blaster air tool conditioner a try tho.
Old Nov 26, 2006 | 05:46 PM
Hairy Gorilla's Avatar
Default Re: (drift4jesus)
Will simple WD-40 work? My driver window can barely roll down in the cold weather. Going up isnt as much of a problem. If not I will try ACE and see if I can't find this stuff from TI
Old Nov 26, 2006 | 07:00 PM
kynetik's Avatar
Default Re: (Tim Maryak)
wd-40 works but not very well; it only lasts a day or so before it starts sticking again. my dad has this problem on his 96 accord and he basically drenched the tracks with wd40, which helped but its definitely not a permanent solution. silicone spray or the team integra article would be better ideas.
Old Nov 26, 2006 | 07:02 PM
Quitripin's Avatar
Default Re: (kynetik)
Honda/Acura uses a grease called SHIN ETSU, you can get it at the dealership works really great
Old Nov 26, 2006 | 07:43 PM
spikehairboy's Avatar
white silicon lubricant spray
Old Nov 27, 2006 | 08:19 PM
Default Re: (spikehairboy)
Thanks i'll run to ACE tomorrow and see if I can't find something of this sort..
Old Nov 27, 2006 | 08:25 PM
92DAIntegraXSI's Avatar
Default Re: (Quitripin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quitripin &raquo;</TD></TR><TR><TD CLASS="quote">Honda/Acura uses a grease called SHIN ETSU, you can get it at the dealership works really great </TD></TR></TABLE>
That stuff works great we use it on the newer cars that have that window safety thing so kids can not get there heads stuck when the windoe is going up. the dirt restricts the window and the auto up feature likes to have a mind of its own. so the serivce bulletin says to clean the run chanels with a mild cleaner and apply the SHIN ETSU grease works great!!!
240MANSX
Dec 12, 2007 10:09 AM
BORACHO
37
Dec 2, 2007 03:02 PM
Jonathan_ED3
Jul 5, 2006 01:52 PM
civiccoupe94
16
Dec 27, 2005 04:01 PM
0ptimus prime
Mar 16, 2004 09:37 AM
