HID brightness?
Hey guys,
i currently own an ef and wanted to retrofit an HID kit from an s2000, but i was wondering how many kelvin(edit) it is? i was thinking somewere around 6000k but i wasn't sure.
thanks
thanks
as a side note, it's not the color temp that provides you with enough info for good light output. If you can find the amount lumens that the S HIDs are, that will give you a better idea of how much light is getting put on the ground.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScreaminTeg »</TD></TR><TR><TD CLASS="quote">as a side note, it's not the color temp that provides you with enough info for good light output. If you can find the amount lumens that the S HIDs are, that will give you a better idea of how much light is getting put on the ground.</TD></TR></TABLE>
That is true. A higher bulb temperature would have a lower light output in lumens.
gyrmaersk
27
Jun 20, 2006 03:05 PM
rookshot06
Feb 18, 2003 03:50 PM
