Honda S2000 Honda S2000
HID brightness?
Old Mar 26, 2006 | 09:08 AM
nk2k2's Avatar
Default HID brightness?
Hey guys,
i currently own an ef and wanted to retrofit an HID kit from an s2000, but i was wondering how many kelvin(edit) it is? i was thinking somewere around 6000k but i wasn't sure.
thanks
Old Mar 26, 2006 | 09:09 AM
Mr. Projekt's Avatar
* B A N N E D *
Default Re: HID brightness? (4g4d)
4300 or 4700 "kilowatts" ROFL. They're called Kelvin, light temperature measurements.
Old Mar 26, 2006 | 09:10 AM
nk2k2's Avatar
Default Re: HID brightness? (ProjektSlideways)
thanks for the quick reply. my bad on the "kilowatts".
Old Mar 26, 2006 | 10:24 AM
SuzukaBlueAP2's Avatar
as a side note, it's not the color temp that provides you with enough info for good light output. If you can find the amount lumens that the S HIDs are, that will give you a better idea of how much light is getting put on the ground.
Old Mar 26, 2006 | 10:29 AM
* B A N N E D *
Default Re: HID brightness? (ScreaminTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScreaminTeg &raquo;</TD></TR><TR><TD CLASS="quote">as a side note, it's not the color temp that provides you with enough info for good light output. If you can find the amount lumens that the S HIDs are, that will give you a better idea of how much light is getting put on the ground.</TD></TR></TABLE>
That is true. A higher bulb temperature would have a lower light output in lumens.
EJ8 GSR-T
Dec 25, 2006 09:34 PM
gyrmaersk
27
Jun 20, 2006 03:05 PM
DC2_2
Jun 6, 2006 11:09 AM
rookshot06
Feb 18, 2003 03:50 PM
