wierd eletrical problem
Old Mar 26, 2006 | 08:25 AM
beyondspexj's Avatar
Default wierd eletrical problem
ok here is the situation. as of right now my highbeams, rear wiper, rear squirter, front squirters, and 3rd brake light do not work. non of these are serious but its got me really curious as to why they are not working. ive checked for fuses under the dash and in the box in the engine bay. there are no blown fuses. any suggestions? the car is all stock. ( 91 Si hatch ) so there is nothing tapped into any harnesses. only thing is a pionner cd player and that was hooked up properly.
Old Mar 26, 2006 | 09:30 AM
jdeemseerx's Avatar
sounds to me like your multiswitch is f'd..if youve got a multimeter i would check that out and also see if you have voltage at the high beam plugs when they are on..did you check to see if the 3rd brake light is blown?
Old Mar 26, 2006 | 05:16 PM
yea i even changed the bulb and still nothing. the multiswitch wasnt something i thought about. ill have to check that.
FrozenPenguin
Oct 15, 2008 09:25 PM
Jeff
Nov 22, 2006 03:45 AM
jeffk182
Jan 25, 2005 11:27 AM
pumonchu2005
Nov 25, 2004 01:12 AM
dangerous will
Dec 21, 2002 02:11 PM
