cluster ?'s
I have a dx hatch, I bought an si cluster, put it in my car, and it didn't work. I figured that for tha tack I would have to run some wires, but everything else sould work???? shouldn't it???? The only thing that works proper is the speedo, and the r/turn signal flasher in the cluster. Fuel guage doesnt work. Temp guage works about 1/2 till I turn on my L/turn signal. The green arrow doesn't flash you can hear the click sound, and the temp guage junmps all the way up. Like I said everything sould work other then the tack??? Thhe funny thing is that the tack works sometimes mainly from the 2k rpm range, and up. Did I get ripped off or is their more wires to hook up. Should I just pilled a hundred dollar bill out of my wallet and burnt it. I f-ing hate shifty, shady, shiesta mother f-kers.
Everything was in working order before I changed the cluster, but on the back of the new cluster it had a 3rd plug on it. I figured that that was for the tack. When I pluged the two plugs in I pushed till I herd a click, and the same when I plugged in the speedo.
DatOneGuy
20
Jan 25, 2015 10:45 AM
civiccpedx
May 18, 2007 06:56 PM
C8V6C
Mar 27, 2006 09:01 AM
Soccer10
Oct 22, 2005 11:16 AM
