ECU modification for JDM engines
Old Mar 25, 2006 | 08:04 PM
Mikevw1's Avatar
Default ECU modification for JDM engines
I am looking to get a JDM front clip and graft it into the rear of my '71 VW Bug. The issues I am seeing are the locking the steering into the straight position and getting the engine to run without having to figure out all the wiring and sensors. I want an automatic transmission mainly because I don't want to run the manual transmission cables. My question is does anybody know if JET Chips can modify the ECU to make the motor run without all the sensors and wiring? I am thinking about a Civic because the wheel track is about the same width as the Bugs. Thanks for your help.
Old Mar 27, 2006 | 06:32 PM
Mikevw1's Avatar
Default Re: ECU modification for JDM engines (Mikevw1)
Nobody has a clue? Did I stump you?
Old Mar 27, 2006 | 06:49 PM
PURPLETERROR aka BIGMATT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mikevw1 &raquo;</TD></TR><TR><TD CLASS="quote">Nobody has a clue? Did I stump you?</TD></TR></TABLE>
no, your retardation just astounds us
Old Mar 27, 2006 | 07:19 PM
Mikevw1's Avatar
Default Re: ECU modification for JDM engines (PURPLETERROR aka BIGMATT)
Is this all the Honda world has to offer? I can get second rate insults anywhere.
Old Mar 27, 2006 | 07:29 PM
Jim Truett's Avatar
Wouldn't it be more fun to use an Accord V6 and bolt it up to a bus-box. Adapter plates are available, and the engines are damn cheap. Just tune a Haltech for it to eliminate the sensor issues. Total cost roughly $2500.00, probably considerably cheaper than the clip you are looking at.
OzzManG149
Jan 10, 2007 08:22 PM
GsRated
Sep 26, 2006 05:14 AM
SpiderSol
Dec 4, 2005 06:08 PM
DasaEJ1
Aug 10, 2005 06:42 PM
DB8ITR
Dec 6, 2003 12:34 AM
