did teg cluster swap and wired shit wrong..pls help
Old Mar 25, 2006 | 07:53 PM
gsxr1k05's Avatar
Default did teg cluster swap and wired **** wrong..pls help
i am gonna double check my wiring tomamrow, but here are my probelms. the ebrake light is hooked to the highbeam switch, and the turn signal indicators dont work. i dont have the vss installed yet, i still have to grind off the mounts (its from a civic) and i have the stock d15b, but the vss is from a stock d15 civic, so i should be ok...) other than that, run the vss wiring, and hope the speedo works. i am going to wire the signal wire into the vss signal in the crx wiring harness, and the vss amp signal wire in the harness. both located in the dash behind the cluster. i wont be doiung the wire stright to the ecu like i have seen so many times. should work.. hope that i can fix the ebrake and turn signals.. let me know if this is a common problem, and the fix..
thanks
InTheLBC20
22
Aug 6, 2010 01:59 AM
Turbo Dan
20
Aug 5, 2008 09:46 PM
hatchyboy89
Feb 2, 2006 06:00 AM
B20EF
Jan 26, 2006 03:06 PM
