rear wheel bearing ???
i'ved searched and searched and havent found an actual answer.
is it possible to just replace the rear wheel bearing without having to buy the whole hub assembly? i read yes and no so i just want to make sure. would greatly appriciate an answer. thanx
just go to a LOCAL autoparts store like ADVANCE auto they will have a rear hub assy. for like $50 if your car is a integra that is..
go with that it works fine i did it for my friend... if you get the bearings you will have to go get the old bearings pressed out which will cost you alittle bit more money... so go to ADVANCE... good luck..
PaChiLa Leader
Feb 18, 2009 05:21 PM
redman223
Apr 30, 2007 02:36 PM
Hemix
10
Mar 5, 2007 06:12 PM
