Dented oil pan....
Old Mar 25, 2006 | 05:42 PM
VegaS10's Avatar
Default Dented oil pan....
I ran over a ******* muffler on the way home tonight. No body damage, and the car drove like normal for about 15 miles home at highway speeds. The alignment is a bit off now, but, the pan is my main concern. It is dented, but nothing really major.
Should I be concerned?
Old Mar 25, 2006 | 05:46 PM
gnar kill's Avatar
Default Re: Dented oil pan.... (VegaS10)
if it is running....I wouldn't...as long as it isn't leaking and not too FUBAR
Old Mar 25, 2006 | 06:03 PM
VegaS10's Avatar
No leaks, just a nasty dent.
Old Mar 25, 2006 | 06:34 PM
Mr_CRX's Avatar
Default Re: (VegaS10)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VegaS10 &raquo;</TD></TR><TR><TD CLASS="quote">No leaks, just a nasty dent.</TD></TR></TABLE>
The only thing I'd be worried about is the oil pickup. It sits really low in the pan. If the dent is in the right spot, it could bend the oil pickup and restrict flow.
When I bought my motor, it had pretty big dent in the pan. Here's what I found after removing the pan.
I'd at least pull the pan off and see how the oil pickup looks. If it's okay, just grab a rubber mallet and hammer the pan back out.
Old Mar 26, 2006 | 04:02 AM
StorminMatt's Avatar
Default Re: (Mr_CRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr_CRX &raquo;</TD></TR><TR><TD CLASS="quote">If it's okay, just grab a rubber mallet and hammer the pan back out.</TD></TR></TABLE>
Better yet, go to the local pick-and-pull and get an undented pan. And just grab the pickup while you are at it. It should be cheap.
Old Mar 26, 2006 | 04:22 AM
ijjz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr_CRX &raquo;</TD></TR><TR><TD CLASS="quote">The only thing I'd be worried about is the oil pickup. It sits really low in the pan. If the dent is in the right spot, it could bend the oil pickup and restrict flow.</TD></TR></TABLE>
Listen to this guy, it does sit low.
Old Mar 26, 2006 | 05:25 AM
h23civic's Avatar
post a pic of the dent, i hit a pretty bad pothole that dented my oil pan up a good amount and my pickup wasn't damaged . i wouldn't get a new pickup unless you know yours is damaged. if its that bad pull the pan, and check everything out, you can do as said above and hammer the thing out if you want. i'd post a pic or something thought just so everyone can get an idea of how bad you hit the muffler and if it could have caused any pickup damage.
Old Mar 26, 2006 | 06:21 AM
HamiltonRex's Avatar
I'd at least pull the pan off and see how the oil pickup looks. If it's okay, just grab a rubber mallet and hammer the pan back out.</TD></TR></TABLE>
Same thing with mine..
I wasnt hitting vtec, low oil pressure. So i pulled the pan, and the pickup was munched agasint the bottom of the pan..
Old Mar 26, 2006 | 07:50 AM
Burlyirishdude's Avatar
Default Re: (HamiltonRex)
Make sure the pickup is ok....make sure the screen is clean might as well since you have the pan dropped. replace the gasket and put a new pan on. It's easier then worrying about whether or not your leaking. Plus it's like 5$....
Get rocca pads to stop your leak.
Old Mar 26, 2006 | 07:57 AM
beyondspexj's Avatar
would anyone happen to know if all the d series pickups ( except for the d16y8 ) and that shield are the same and interchangeable?? just bought a bare block and i mean BARE
Old Mar 26, 2006 | 10:50 AM
92 si hatch's Avatar
I would be most worried about the pick-up. My opinion would be to get a new one and oilpan and gasket. Beter safe then sorry. much easier to replace this stuff the a motor.
DrSeuss
Jun 20, 2007 06:34 PM
RHDintegXsi
Jun 17, 2006 04:20 AM
tekstyle
May 2, 2006 11:47 AM
sd.coupe
Feb 19, 2006 07:09 PM
civickiller
May 17, 2003 08:35 AM
