NEED HELP! How to grind tungsten?
Old Mar 25, 2006 | 05:11 PM
untuned's Avatar
Default NEED HELP! How to grind tungsten?
I can't afford a tungsten grind, what are your methods of grinding tungsten?.. I never get the same grind.
Thanks
Old Mar 25, 2006 | 05:40 PM
Motorhead_AZ's Avatar
Default Re: NEED HELP! How to grind tungsten? (untuned)
I use a 6" bench grinder to sharpen my tungsten. I bought it for $20 from Harbor Freight. Hold the tungsten tangent to the surface of the wheel until you achieve your desired tip. Just make sure nothing else ever touches that wheel, cause that'll contaminate the tugnsten.
Old Mar 25, 2006 | 06:03 PM
Race Egr's Avatar
Default Re: NEED HELP! How to grind tungsten? (Motorhead_AZ)
what he ^^^^ said although I really am thinkin about buyin a tungsten grinder because seems like everytime i go to use my grinder somone else has grinded something else with it
Old Mar 25, 2006 | 06:11 PM
Zornig's Avatar
Default Re: NEED HELP! How to grind tungsten? (NAPIER)
I also use a dedicated ginder just for tungsten. Only difference is I chuck mine up in a cordless drill, makes for a very uniform finish.
Old Mar 26, 2006 | 05:28 AM
JustaZC's Avatar
Default Re: NEED HELP! How to grind tungsten? (Zornig)
Screw all that junk.....this stuff here http://www.welding-direct.com/chemtunpoinp.html is the heat!!!! Just do like it says, and it work like a charm. Or you can just hit the tungsten with a MAP torch till hot. The chemical reaction with the powder keeps the tip lava hot while immersed in it.
Old Mar 26, 2006 | 04:28 PM
93LSivic's Avatar
Default Re: NEED HELP! How to grind tungsten? (JustaZC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JustaZC &raquo;</TD></TR><TR><TD CLASS="quote">Screw all that junk.....this stuff here http://www.welding-direct.com/chemtunpoinp.html is the heat!!!! Just do like it says, and it work like a charm. Or you can just hit the tungsten with a MAP torch till hot. The chemical reaction with the powder keeps the tip lava hot while immersed in it. </TD></TR></TABLE>
Interesting! Anyone else use this with good results?
Old Mar 26, 2006 | 04:46 PM
dfoxengr's Avatar
Default Re: NEED HELP! How to grind tungsten? (93LSivic)
i use a grinder that gets other stuff ground on it all the time. and no problems.
the proper technique also is the tip pointing up
Old Mar 31, 2006 | 02:21 PM
RC000E's Avatar
Default Re: NEED HELP! How to grind tungsten? (dfoxengr)
Yeah, I use a grinder which sees other materials as well. Probably not the best method, but I never seem to have any problems. If I were really doing something structural though, I'd probably go the clean route. I do at least hit the tip with brake cleaner after I sharpen...doesn't do much for embedded contamination though, just surface.
It's certainly all about the point and the length of the tip.
Old Mar 31, 2006 | 05:03 PM
19civic93's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zornig &raquo;</TD></TR><TR><TD CLASS="quote">I also use a dedicated ginder just for tungsten. Only difference is I chuck mine up in a cordless drill, makes for a very uniform finish.</TD></TR></TABLE>
Same here. This way's the best if you don't buy a tungsten grinder. I actually see no need to buy one. A lot of guys on the welding forums don't even use them. They all seem to use this technique.
Old Apr 1, 2006 | 07:21 AM
Fred Allen Burge's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dfoxengr &raquo;</TD></TR><TR><TD CLASS="quote">i use a grinder that gets other stuff ground on it all the time. and no problems.
the proper technique also is the tip pointing up </TD></TR></TABLE>
I'm curious what difference it would make if it was pointed up or down??
Fred
Old Apr 2, 2006 | 03:30 PM
Default Re: NEED HELP! How to grind tungsten? (Fred_Allen_Burge)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fred_Allen_Burge &raquo;</TD></TR><TR><TD CLASS="quote">
Fred</TD></TR></TABLE>
I think what he meant was not to hold the tungsten sideways.
I just snapped some pictures to help visualize the procedure:
Start with a "dull" tungsten:
Put it on the grinder wheel as shown below, and turn it in a clockwise or counterclockwise motion to grind all around it:
Grind it until you achieve your desired tip:
And after you grind a few of tungstens, you get a "channel" engraved on your grinder wheel. This makes it a lot easier to grind the tungsten, as it won't move side to side on the wheel. I recently bought this grinder, but you can see that I already have a "channel", even though it's quite shallow right now.
Old Apr 3, 2006 | 08:07 AM
VTIDelSol's Avatar
That is a sick point! Nice camera shots too.
Old Apr 3, 2006 | 11:04 AM
Default Re: NEED HELP! How to grind tungsten? (HybridKOOP)
Yes, it's terrible, awful results!
I'm not on my home computer, otherwise I'd show you some of my terrible looking steel and SS welds too.
Old Apr 3, 2006 | 11:16 AM
jdmek910's Avatar
youll get fine enough results using a bench grinder... but if u wanna be all technical to show off to the newbs ... yes the arc will not travel as direct as it would with a $1000+ tungsten grinder
Old Apr 3, 2006 | 01:12 PM
VTIDelSol's Avatar
Default Re: NEED HELP! How to grind tungsten? (jdmek910)
Those welds look disgusting…what kind of camera?
Old Apr 3, 2006 | 11:55 PM
5STAR3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Motorhead_AZ &raquo;</TD></TR><TR><TD CLASS="quote">Yes, it's terrible, awful results! </TD></TR></TABLE>
i think he may have been referring to welding aluminum, and how you ball the tip. but you still grid it first.
Old Apr 4, 2006 | 02:42 AM
19civic93's Avatar
Default Re: NEED HELP! How to grind tungsten? (5STAR3)
scroll down to the middle.http://www.millerwelds.com/edu....html
Modified by 19civic93 at 12:03 PM 4/4/2006
Old Apr 4, 2006 | 06:08 PM
untuned's Avatar
Default Re: NEED HELP! How to grind tungsten? (19civic93)
thanks for everyone's help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 19civic93 &raquo;</TD></TR><TR><TD CLASS="quote">scroll down to the middle.http://www.millerwelds.com/edu....html
Modified by 19civic93 at 12:03 PM 4/4/2006</TD></TR></TABLE>
awsome info
lankan-balla
Paint and Body
Jun 26, 2013 06:54 PM
Sandals
Sep 14, 2006 08:00 PM
ExCon
Nov 11, 2005 07:38 PM
92BlackSi
Audio / Security / Video
Apr 21, 2004 01:59 PM
HaUTSaauce
Apr 2, 2002 07:45 PM
