what do you think about these flanges? + anoter qouestion about manifold tubing.
Old Mar 25, 2006 | 04:03 PM
RACEPAK's Avatar
Default what do you think about these flanges? + anoter qouestion about manifold tubing.
hello.
i'm making a turbo manifold for a friend and i need to know whatsize of pipng to use. the hole diameter is: 39mm * 30mm.
some local metal lazer cutting shop did these flanges tor quite cheap.
what do you think about them?
they are 12 mm thick.
Old Mar 25, 2006 | 08:15 PM
Bailhatch's Avatar
Default Re: what do you think about these flanges? + anoter qouestion about manifold tubing. (RACEPAK)
as long as you have a drill press and a little time those are probably a good deal if they are under 15 USD.
I love how everything is metric in every country but here. metric system
or is your 12mm really 1/2inch? 12.7mm?
Modified by Bailhatch at 4:12 PM 3/26/2006
Old Mar 26, 2006 | 05:10 AM
RACEPAK's Avatar
Default Re: what do you think about these flanges? + anoter qouestion about manifold tubing. (Bailhatch)
i'm paying 9-10$ for each flange. and 5-3$ for a turbo inlet\outlet flanges.
its 12 mm.
Old Mar 26, 2006 | 05:18 AM
weiRtech's Avatar
OG Fabricator
that is pretty cheap, but they should have put the holes in for you, it would save you a lot of time. was there any particular reason why they didn't add them?
as for piping, pick up some schedule 10 304ss 1.5" elbows and pipe.
Old Mar 26, 2006 | 10:53 AM
RACEPAK's Avatar
Default Re: (weiRtech)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by weiRtech &raquo;</TD></TR><TR><TD CLASS="quote">that is pretty cheap, but they should have put the holes in for you, it would save you a lot of time. was there any particular reason why they didn't add them?
as for piping, pick up some schedule 10 304ss 1.5" elbows and pipe.</TD></TR></TABLE>
they wanted 3$ more for making the holes. i have a foot drill so i dont mind.
Old Mar 26, 2006 | 09:20 PM
VRD^don's Avatar
Default Re: (RACEPAK)
you got a killer deal..
QwkD16
Welding / Fabrication
18
Sep 20, 2012 06:55 AM
905_Legend
20
Nov 2, 2006 01:28 PM
Snail Tuning
Aug 24, 2005 10:50 AM
cstay
Jul 10, 2005 11:03 AM
LostCRX
84
Feb 27, 2005 12:55 PM
