USDM ITR tranny a direct drop in on a gs-r motor?
Old Mar 25, 2006 | 03:34 PM
hott-nix's Avatar
Default USDM ITR tranny a direct drop in on a gs-r motor?
will i be able to take my gsr transmission out and just bolt the type-r tranny in or do i have to change anything else?
also, if i buy it, i'll be installing a new clutch and flywheel. clutch/flywheel are the same for both gsr and itr right?
Old Mar 25, 2006 | 05:03 PM
hondanuts's Avatar
Default Re: USDM ITR tranny a direct drop in on a gs-r motor? (hott-nix)
yep everythings the same
Old Mar 25, 2006 | 06:50 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: USDM ITR tranny a direct drop in on a gs-r motor? (hondanuts)
To confirm, yes it will bolt on with no modifications at all.
Old Mar 26, 2006 | 07:41 AM
Cole D's Avatar
Default Re: USDM ITR tranny a direct drop in on a gs-r motor? (shamoo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shamoo &raquo;</TD></TR><TR><TD CLASS="quote">To confirm, yes it will bolt on with no modifications at all.</TD></TR></TABLE>
Old Mar 26, 2006 | 08:55 AM
PhaKe TyPe R's Avatar
Default Re: USDM ITR tranny a direct drop in on a gs-r motor? (Cole D)
Old Mar 26, 2006 | 09:56 AM
DADADAAAMN's Avatar
si senor!
Old Mar 26, 2006 | 07:40 PM
stumpyf4's Avatar
Just did this on Friday.... bought a new ITR tranny with a Exedy Stage 1 and ACT streetlight flywheel. Tranny came with the reverse switch already installed, only had to reuse my VSS from my GSR tranny.
So fun to drive with the shorter geared tranny!! 1-2 shift is awesome!!
Old Mar 27, 2006 | 08:03 AM
hott-nix's Avatar
Default Re: USDM ITR tranny a direct drop in on a gs-r motor? (stumpyf4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stumpyf4 &raquo;</TD></TR><TR><TD CLASS="quote">Just did this on Friday.... bought a new ITR tranny with a Exedy Stage 1 and ACT streetlight flywheel. Tranny came with the reverse switch already installed, only had to reuse my VSS from my GSR tranny.
So fun to drive with the shorter geared tranny!! 1-2 shift is awesome!!</TD></TR></TABLE>
hope you dont mind, but i'm gonna pm you
red-teg!
Apr 1, 2007 05:27 PM
vtecpower1062
Dec 12, 2004 10:07 PM
.doeboyfresh.
May 21, 2004 09:53 AM
zigs
Dec 22, 2003 07:15 PM
stupidfast
Feb 20, 2003 07:51 PM
