passenger airbag connections
Old Mar 25, 2006 | 03:19 PM
-Todd-'s Avatar
Default passenger airbag connections
Does anyone know where this connector is supposed to go? Also are the other connectors plugged in correctly? the red and other yellow connector?
Old Mar 25, 2006 | 04:39 PM
Teggys1ClnDA's Avatar
Default Re: passenger airbag connections (-Todd-)
I'll check it out in the morning.
Old Mar 25, 2006 | 09:28 PM
-Todd-'s Avatar
Default Re: passenger airbag connections (Milano00Prelude)
bump before bed
Old Mar 25, 2006 | 09:36 PM
SYTFU Tommy.'s Avatar
take out the red plug where the airbag is and plug the two air bags wires together. remeber that yellows are srs
Old Mar 25, 2006 | 09:57 PM
-Todd-'s Avatar
Default Re: passenger airbag connections (tngay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tngay &raquo;</TD></TR><TR><TD CLASS="quote">take out the red plug where the airbag is and plug the two air bags wires together. remeber that yellows are srs</TD></TR></TABLE>
That's what I was thinking, but the yellow connectors wont fit together. I think the airbag is from an obd1 integra, while mines a obd2a. Is there a difference between the airbags?
Reid's Avatar
Global Moderator
Your airbag has been disabled.
Plug the two yellow plugs together to enable it.
Old Mar 26, 2006 | 07:13 AM
-Todd-'s Avatar
Default Re: passenger airbag connections (Reid)
Okay I think I found the problem. The dash had been changed, and the winners that owned the car before me did'nt switch the bags knowing the connectors did'nt fit together so they just disabled the passenger airbag. I checked the part numbers for integra ls passenger airbags, I assume the bags are the same for a rs, gsr, etc.
06780-ST7-A70ZA 01 integra ls
06780-ST7-A70ZA 00 integra ls
06780-ST7-A70ZA 99 integra ls
06780-ST7-A70ZA 98 integra ls
06780-ST7-A90ZA 97 integra ls
06780-ST7-A90ZA 96 integra ls
06780-ST7-A80ZA 95 integra ls
06780-ST7-A80ZA 94 integra ls
Old Mar 26, 2006 | 07:56 PM
yeah, obd2a and odb1 airbags arent the same. i learned that the hard way and bought a obd1 driver side airbag when i have a obd2a....
Old Mar 27, 2006 | 07:37 AM
Ftrceo's Avatar
im having the same problem right now with my car reconstruction. I either have hte wrong year airbag or the wrong year yellow srs harness. can i clip off the connectors and put connect the two wires with some quick connects? everything else I have connects fine except the passenger airbag.
Thanx!
Old Mar 27, 2006 | 02:27 PM
dwolsten's Avatar
Default Re: passenger airbag connections (Ftrceo)
You probably can, but I don't think I'd take the chance. Soldering the wires connecting to the airbag is a very bad idea; a small static charge could set off the explosive.
If you're really determined to connect an airbag to the wrong harness, you should get a mating connector and solder it to the harness (with it disconnected from everything else).
Your best bet is to just get the correct airbag.
Old Mar 27, 2006 | 02:52 PM
Solscud007's Avatar
Default Re: passenger airbag connections (dwolsten)
I found out about the aribag differences when i switched to non SRS ITR wheel. I was trying to hook up my horn and the how to guide refers to a grey SRS plug that I didnt have, looked around and found another how to guide.
Old Mar 27, 2006 | 07:40 PM
-Todd-'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dwolsten &raquo;</TD></TR><TR><TD CLASS="quote">You probably can, but I don't think I'd take the chance. Soldering the wires connecting to the airbag is a very bad idea; a small static charge could set off the explosive.
Your best bet is to just get the correct airbag.</TD></TR></TABLE>
I have the connector from the 97 airbag, but I dont want to risk it. How would I go about finding a mating connector? I could just buy a 97 bag and sell the 95 bag that I have.
robs97
Feb 15, 2008 11:04 AM
zman
Mar 7, 2005 11:04 AM
S88HON
Oct 4, 2004 04:19 PM
shauniewalnuts
13
Oct 24, 2003 07:14 AM
elnoyl
Mar 5, 2003 06:24 PM
