Prelude suspension question
Old Apr 3, 2002 | 04:38 AM
99Interlude's Avatar
Default Prelude suspension question
Im wicked lost i need major help, i wanted a coilover system a little while ago but after reading about it i seen i didnt wanna deal with cornerweights and all that junk, so i thought about a shock/spring combo, but i dont wanna lower it to much
eliminate the gap thats about it cause my kit is to low and lots of hills i nearly scrape with my stock bumper!!! so i need some ideas guys info what would u pick also the roads suck!
Coilover or Shock/Spring combo, if you went with the second answer which ones? no more than 1.4 drop
Old Apr 3, 2002 | 05:11 AM
Anubyss's Avatar
Koni/HR combo is pretty damn good.
Old Apr 3, 2002 | 05:13 AM
thats a bit 2 low
Old Apr 3, 2002 | 05:30 AM
Mugenlude's Avatar
Default Re: (99Interlude)
I would still get the GC's. You don't have to deal with corner weights unless you choose to.
Old Apr 3, 2002 | 05:33 AM
Default Re: (Mugenlude)
i hate GC's but if dont deal with cornerweights whats the point of even getting a coilover system...
Old Apr 3, 2002 | 05:44 AM
tec-9-7's Avatar
Do U have the $$$ for Mugen? Thats a plug-n-play spring shock combo that gives U a 1" drop F/R...
Paul
Old Apr 3, 2002 | 05:49 AM
Default Re: (tec-9-7)
waste of money $1000+ for a 1" drop bleh, not worth it
Old Apr 3, 2002 | 06:21 AM
Mugenlude's Avatar
You get to pick the spring rates & you have adjustable ride height.
[Modified by Mugenlude, 3:23 PM 4/3/2002]
Old Apr 3, 2002 | 06:24 AM
ya but dont wanna deal with it, lets keep it simple spring and shock combo .. which ones do ya recommend now.
Old Apr 3, 2002 | 06:26 AM
tec-9-7's Avatar
Man, you're shooting down everything anyone suggests - seems like we're running thin on ideas...
I'll try once more tho - it's been a while since I've checked but I think Apex'i makes sport springs that give a 40mm drop - combine these w/ Koni yellows which have an adjustable perch height and you should be able to get close to 1.4"
Paul
[Modified by tec-9-7, 7:32 AM 4/3/2002]
Old Apr 3, 2002 | 06:31 AM
ya see, thats not the issue man but heres the downsides i dont like.
GC - Bad previous experience to bouncy and made noises sucked.
H&R - too low
Coils - rad alot on them cornerweights adjustibility, and such scared me away.
eibach - seems my only choice right now but i heard they dont function well with koni yellows.
neuspeed - they dont match the car all around and they lower 1.5
progress - same issue 1.5 once it settles it ends at about 1.7 or so my kit would snow plowing everything and the pot holes here bite!!!.
Anubyss's Avatar
Why would Koni/HR be too low? HR sports are 1.4" drop. If that's too much then adjust the perch setting for less of a drop.
Old Apr 3, 2002 | 06:36 AM
Default Re: (Anubyss)
anubiss, i was gonna go for the h&R sports but have you seen the setup, of the R34 front,bw sides ,bc rear, the front hangs low, im afraid of scrapping the thing to death being fiberglass .
eibach - i hear the sag after a little while
[Modified by 99Interlude, 3:44 PM 4/3/2002]
Old Apr 3, 2002 | 06:42 AM
Anubyss's Avatar
Here is a pic of my car with the Koni/HR combo.
That is the middle perch I believe. You can choose to raise it by using a different perch though.
[Modified by Anubyss, 3:43 PM 4/3/2002]
Old Apr 3, 2002 | 06:49 AM
wow you still look like your stock high, i'd def be using the the last perch, i need to be lowered a lil bit more than that, i was looking at hp.com some ppl that say they got the H&R/Koni combo, looked alot more lowered than that 1-2finger gap u got a at least 4 there.
Old Apr 3, 2002 | 07:01 AM
dflipmode's Avatar
i've heard that lowering the 5th gen is not good?...is this true?...some guy posted in PO.com that two of his buddy broke the axles bcoz of the drop...is that really a problem with the 5th gen?
Old Apr 3, 2002 | 07:11 AM
Anubyss's Avatar
Only 2 finger gap. It may look like four but it's not.
Old Apr 3, 2002 | 07:39 AM
dflipmode: never heard of such a prob maybe if it was a SH that might of been it, 2 fingers, wow... i might haft lower it lower than.
Old Apr 3, 2002 | 07:58 AM
Default Re: Prelude suspension question (99Interlude)
i found it here it is same exact setup i got , see how low she is with H&R's not even koni!!! http://www.hondaprelude.com/setups/s...y.asp?id=16280
damn for the lazy ones heres a pic.
shes got the exact same setup as my sig.
[Modified by 99Interlude, 5:30 PM 4/3/2002]
Old Apr 3, 2002 | 08:27 AM
Smurfylude's Avatar
I definately say stay away from GC's. Worst product on the market. If you want used GC's I'll give you mine with front Koni Yellow's for $50 plus shipping. I have Tein HA on all four coners and they are the Sh@t! Save your money and get real coilovers.
Old Apr 3, 2002 | 08:33 AM
Default Re: Prelude suspension question (Sushi X)
i got the money for HA but why do i need it its for daily drivin, SS works just fine but why get coilovers i'll touch them probobly once a year, and my ride suffers because its not properly tuned.
ribal_gh
Suspension & Brakes
Jan 19, 2013 11:49 AM
swizz977
Suspension & Brakes
Sep 9, 2012 11:49 AM
hondaaaaah
10
Mar 12, 2004 10:07 AM
jweller
Nov 1, 2003 05:29 PM
JeremyL
Feb 15, 2003 08:22 AM
