Need advise badly
Old Mar 25, 2006 | 10:46 AM
garyc17's Avatar
Default Need advise badly
I have been having a bad time with my B18C5 for the last 2 months. Firstly, the car started throwing CELs 6 to 7 blinks. I changed my plugs and the problem started to lightened becoming 3 blinks during driving. So I got the expertise of some forumers and realised that I had to adjust my TPS which was out of spec. I adjusted it to 0.45V and played with the idle screw to try and also solve a fluctuating rev at idle. Checked the IACV too. IACV was well. CEL stopped throwing codes. But during the 6 to 7 blinking days, there started to have oil leaks at the head gasket just above the engine block number. I just spoke to a friend and he tells me its most likely a blown head gasket. The problem I face now is upon light throttle and upon throttle release at almost any speed and RPM, the car jerks and hesitates. I have no problem at idle though. Also the power has dropped tremendously since I got the car from the previous owner. What should I do now? I don't wish to waste money doing the wrong stuff and get the car fixed once and for all! Please advise me.
Old Mar 25, 2006 | 12:07 PM
vegas36's Avatar
Where are you located? I would take it to a trusted shop and have them check it out.
Old Mar 25, 2006 | 12:40 PM
jdmspoonitr's Avatar
Default Re: (vegas36)
Sounds like u bought a motor that was ragged on. good luck with that
Old Mar 25, 2006 | 04:41 PM
nightrider's Avatar
Default Re: Need advise badly (garyc17)
leakdown test? compression test?
<------- ???? just hopin you will figure out the problem.
Old Mar 26, 2006 | 07:37 AM
garyc17's Avatar
Default Re: Need advise badly (nightrider)
I was thinking of the leak down test too. I heard that you can change a certain rubber seal on the head gasket without having to replace the whole gasket. Is this true? If the leak down is ok, what could be the cause?
7861prada
Apr 8, 2010 02:25 PM
taimysho0
Feb 7, 2009 04:01 PM
95dc2teg
Sep 11, 2007 05:49 PM
garyc17
Mar 26, 2006 08:08 AM
ian.
22
Jan 16, 2005 08:50 AM
