brakes grinding.
Old Mar 25, 2006 | 09:29 AM
xiLLtegRax's Avatar
Default brakes grinding.
just a quick question. i replaced my pads to some cheap pads on my bros car without having the rotor resurfaced. and it makes a loud grinding sound. took it apart and the rotor is rubbing against the new pad. would i have to resurface the rotor or do i just need to brake in the pads?
Old Mar 25, 2006 | 09:34 AM
xiLLtegRax's Avatar
Default Re: brakes grinding. (xiLLtegRax)
oh yea its the rears
Old Mar 25, 2006 | 09:42 AM
shamoo's Avatar
Will you make something up for me please?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xiLLtegRax &raquo;</TD></TR><TR><TD CLASS="quote">took it apart and the rotor is rubbing against the new pad.</TD></TR></TABLE>
Well, I should hope so. Isn't that what brake pads do?
Yes, if you didn't resurface the rotor, then the surface of the rotor won't match the smooth surface of the new pad. It will grind like that for a while until the pad matches the surface of the rotor. You're technically supposed to resurface the rotor every time you change pads, but who has the time/money all the time? I usually do it every other time I change the pads.
Old Mar 25, 2006 | 09:46 AM
xiLLtegRax's Avatar
Default Re: brakes grinding. (shamoo)
yea i knida figure that. i just thought it wouldnt really be this loud since the rotor is pretty dam new. i duno i might just get my rotors turned but it just seems kinda waste since my rotor is practically pretty dam new(about 3-5 month old prob)
Old Mar 25, 2006 | 10:04 AM
shamoo's Avatar
Usually, it doesn't matter how old the rotor is. They have mated to the surface of your old pads, and vice versa.
The grinding isn't supposed to be loud at all. Are you sure nothing else is going on here? Is anything metal grinding on it? The plates/sensors on the pads? Something else?
Old Mar 25, 2006 | 04:10 PM
xiLLtegRax's Avatar
na its not the sensor or anything. i got it fixed though. i think i just needed to break in the new pads but i just said **** it and turn my rotors and broke it in
Old Mar 25, 2006 | 05:04 PM
Ls-VtecR's Avatar
make sure all your rotors are surfaced and u get new pads if not make sure your axel nuts are torqued rite or youll regret it if u total it . no joke
Old Mar 25, 2006 | 05:21 PM
integra3586's Avatar
Default Re: brakes grinding. (Ls-VtecR)
make sure the plates on the back of the pad didnt slip down, and are rubbing againt the rotor hat part. its happened to me before
Modified by B18B-SC at 7:34 PM 3/25/2006
Tenzo
Suspension & Brakes
May 13, 2012 11:03 AM
b16a2EBP
Mar 3, 2006 07:09 PM
civic91
Nov 1, 2005 05:48 PM
B18CYAAA
Oct 1, 2003 08:18 PM
Quick 200k Mile Motor
13
Jan 11, 2002 10:43 PM
