obd2 OIL PUMP difference
Old Mar 25, 2006 | 09:27 AM
SPOOLINmatt's Avatar
Default obd2 OIL PUMP difference
i have an obd1 b18b oil pump on my ls vtec with b18b. Im going to swap out my pump for a new one. I ordered a obd2 civic si 2000 oil pump not thinking about the timing cover might be different. I know this pump will have the provisions for bolting on that positioning sensor which makes the timing cover slightly different. another thing is this pump is like 50$ less than the obd1 b series oil pump, WTF??
Will this pump work for me, will i need to modify my timing cover, i may just buy an obd2 timing cover if there is to much modifying to be done.
i wont have to use the obd2 timing belt sprocket will i?
Old Mar 25, 2006 | 10:56 AM
aj99si's Avatar
Default Re: obd2 OIL PUMP difference (SPOOLINmatt)
the cover will bolt up but there will be a gap between the cover and the oil pump.
boosted k20
Oct 16, 2017 11:11 PM
Egpower88
Jul 21, 2009 02:51 PM
95_red_dc
Aug 15, 2008 02:07 PM
Sassafrass
Jul 21, 2005 08:02 AM
hbkxtbone
Jan 5, 2005 04:12 PM
