Block/Piston Question
Old Mar 25, 2006 | 08:33 AM
DPSJosh's Avatar
Default Block/Piston Question
I have a d15 block (1990 Civic STD DPFI). I can get an awesome deal on a set of brand new pistons and rings for a d16z6. Any chance these pistons would fit in the d15 block with the stock head and everything?
Thanks!
Old Mar 25, 2006 | 10:33 AM
Mach69's Avatar
Default Re: Block/Piston Question (DPSJosh)
I'm not 100% sure, but I think they have a good chance.
I know the bore is the same if that helps any.
Old Mar 25, 2006 | 02:07 PM
jlicrx's Avatar
the pistons will fit, however, compression ratio will be about 7.4:1 due to much larger dish and less compression height on the Z6 pistons
Danial Gooch
Engine Machining & Assembly
Mar 20, 2018 08:40 PM
Einhander276
Sep 10, 2012 10:04 PM
wfocrx
Sep 26, 2006 09:31 AM
TYPErCRX
Jul 23, 2006 11:27 AM
BokChoy
Sep 10, 2005 08:59 PM
