H22 CRX Need help
Old Mar 25, 2006 | 06:16 AM
black_krix_si's Avatar
Default H22 CRX Need help
No its not another how do i put a H22 into a crx thread. The H22 is already in there, and ive searched and googled for hours trying to solve my problem.
You can check out some of the pics here http://www.imagestation.com/al...95512
The car is a 91 crx si. Im using a Locash obd-0 to obd-1 harness for the ecu and distributor and a D16A6 engine harness. I pulled the engine out of a swapped 92 prelude, its a JDM H22A. From what I've read the JDM H22's came with internal coil distributors, but mine is an external. It may have been changed but I dont know for sure. I dont have the H22 harness to get the p.ug for the external coil either.
I need to find out if I can either switch to an internal coil or how to interface the external coil with the crx harness.
Are there any usdm distributors that have an internal coil that will work with my h22?
Ive been told I could probably re-route the wires from the crx harness to the external coil but I'm kinda stumped on that.
Any help is appreciated.
Old Mar 25, 2006 | 06:47 AM
Mugencrxsir1's Avatar
Default Re: H22 CRX Need help (black_krix_si)
I'm not understanding you, I thought all honda's come with internal coils inside the dizzy? Correct me if I'm wrong, the external coil is an aftermarket idea for hondas. So that leads me to believe that you will need to switch to the internal coil, but that's just a stock dizzy. So i'm not sure what your asking, or I'm confused on the internal vs. external coil concept.
Old Mar 25, 2006 | 06:51 AM
Default Re: H22 CRX Need help (Mugencrxsir1)
its an oem distributor, but it has an external coil. I need to find out either how to make the external coil work with my stock crx harness, or what distributor has an internal coil that will work on my h22
Old Mar 25, 2006 | 07:24 AM
2lude4u's Avatar
If you're going to run it internal coil you need an internal H22 Dizzy (as far as I know dizzies for other cars won't bolt on). I have one that I'm selling by the way.
If you want to run it as an external coil I'd suggest getting an MSD ignition & wire it in.
Old Mar 25, 2006 | 09:14 AM
WolfGod's Avatar
you can get a B-series dizzy to work with a little persuasion to the mounting holes
ExplicitSpeed360's Avatar
Banned.
Default Re: H22 CRX Need help (2lude4u)
Factory Engine Harness Distributor Wire Colors
OBD0 OBD1 OBD2A Function
Orange Orange Dark Blue CYPP
White White White CYPG
Orange/Blue Orange/Blue Green TDCP
White/Blue White/Blue Red TDCG
Blue/Green Blue/Green Yellow CKPP
Blue/Yellow Blue/Yellow Black CKPG
Large White Yellow/Green Yellow/Green ICM
Black/Yellow Black/Yellow Black/Yellow IGN output
Blue Blue Blue Tach output
That should help you... determine which wires go to the coil...look and see what 2 wires arent in the distributor plugs
Old Mar 27, 2006 | 05:14 PM
higgunscrx's Avatar
sorry to hijack this thread but hows the hood clearance on the h2b, can you snap some pics on how the hood sits or are you using an aftermarket one?
much appreciated
Old Mar 27, 2006 | 05:32 PM
Default Re: (higgunscrx)
I am going to modify my stock hood. I havent got that far yet though. The motor sits high as you can see in my pics in the side shots.
Old Apr 1, 2006 | 03:42 PM
Ray-mond's Avatar
Default Re: H22 CRX Need help (ExplicitSpeed360)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ExplicitSpeed360 &raquo;</TD></TR><TR><TD CLASS="quote">Factory Engine Harness Distributor Wire Colors
OBD0 OBD1 Function
Orange Orange CYPP
White White CYPG
Orange/Blue Orange/Blue TDCP
White/Blue White/Blue TDCG
Blue/Green Blue/Green CKPP
Blue/Yellow Blue/Yellow CKPG
Large White Yellow/Green ICM
</TD></TR></TABLE> This is the way I did it but I used a MSD box works great this way.just keep the H22 Dizzy. And don't use a P13 ECU use a chip P28 ECU I just used a GSR ECU to get to the dyno. I know with the ExplicitSpeed mounts I have a 3/4 clearance under the hood.
Old Apr 1, 2006 | 04:12 PM
WolfGod's Avatar
Default Re: H22 CRX Need help (1Guamracer)
and whats wrong with a P13? i used it with my swap in my EG and it ran great and got 47.3MPG while doing it
it would be easier to swap it to a B-series dizzy, it works fine and is alot easier, thats what i used on mine
Old Apr 1, 2006 | 05:18 PM
Default Re: H22 CRX Need help (WolfGod)
in the crx the p13 is going to give me an egr code. thats why im going to go with a chipped p28 and do away with it.
And still no fire on the crx yet. im now getting a code 15 after moving some wires around trying to get it to crank.
Old Apr 1, 2006 | 05:42 PM
WolfGod's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black_krix_si &raquo;</TD></TR><TR><TD CLASS="quote">in the crx the p13 is going to give me an egr code. thats why im going to go with a chipped p28 and do away with it.</TD></TR></TABLE>
good reason
Old Apr 1, 2006 | 08:23 PM
Banned.
Good pictures of my traction bar and alternator/tensioner kit I was going through the pictures on your album I was like darn that alternator/tensioner kit looks familar then I see our traction bar and put 2 together...lol
