Idling problem with my d16y8 hatch
My Car won't stop idling funny. Its idling up and down.Even after is warmed up..
This is what i have:
d16y8 motor
p28 Ecu Virgin
Obd 2 Dizzy
I'm not getting any codes from my ecu.
Are these lines right ?
Should these be capped?
Please help I'm lost.
Modified by lvzero0 at 1:39 AM 3/25/2006
Modified by lvzero0 at 2:34 AM 3/25/2006
d16y8 motor
p28 Ecu Virgin
Obd 2 Dizzy
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 143MYVTECEF »</TD></TR><TR><TD CLASS="quote">hm i could be wrong but that red hose coming off the canister looks like it might be hooked up to the wrong place? </TD></TR></TABLE>
I believe thats right.
Also, when I first start my car it doesn't do it. When I'm driving and then stop it does it for about 10 or 20 secs and then it stops..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90 Si Hatch »</TD></TR><TR><TD CLASS="quote">if your idle is going up and down it mite be your IACV = Idle Air Control Valve, or something like that.
Isaac-</TD></TR></TABLE>
like i said, its the little sensor on the back of your intake manifold
i have the same motor in my car but i'm OBD-0 still with a PR3 ecu. i jsut un-pluged it and messed with the idle scru
i have the same motor in my car but i'm OBD-0 still with a PR3 ecu. i jsut un-pluged it and messed with the idle scru</TD></TR></TABLE>
you un-plugged and left it un-plugged?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lvzero0 »</TD></TR><TR><TD CLASS="quote">
you un-plugged and left it un-plugged?</TD></TR></TABLE>
yes, i did and just messed with the idle a little bit, BUT make sure when you do mess with the idle that the car is WARMED up cause if you do it when the car is cold your idle will be fucked up. the only thing that sucks about doing it this way is if you live where it is really cold and you go out to start your car in the morning you will have to turn the key and the give it alittle gas so it doesn't die. by unpluging this sensor you have No cold idle state
2slow4stock
Aug 4, 2007 04:34 PM
