Honda S2000 Honda S2000
How hard would it be to yam an S2K engine into an integra?
Old Apr 2, 2002 | 10:49 PM
Ross's Avatar
25 Year Member
Community Builder
Community Influencer
Active Streak: 30 Days
Default How hard would it be to yam an S2K engine into an integra?
anyone?
Old Apr 3, 2002 | 10:55 AM
SoCal ITR's Avatar
Default Re: How hard would it be to yam an S2K engine into an integra? (Ross)
Nothings impossible, but it's mounted 90 degrees differently than ours. It would suck and I don't think it could be done without MAJOR modification.
Old Apr 3, 2002 | 11:13 AM
Jason W's Avatar
Default Re: How hard would it be to yam an S2K engine into an integra? (SoCal ITR)
Not to mention the Integra is FWD, and the S2000 is RWD. I was looking into doing the same swap a while ago. If you have the money, just go with an RSX-S swap or B18C5.
Of if you have a few good amount of money, don't bother with the S2000 engine, just go by a E36 M3 engine and drop it in there! LOL
Old Apr 3, 2002 | 02:19 PM
Stumpy's Avatar
Default Re: How hard would it be to yam an S2K engine into an integra? (Jasons TEG)
Ross has an ITR.
Old Apr 5, 2002 | 05:32 AM
D-Style's Avatar
Default Re: How hard would it be to yam an S2K engine into an integra? (Stumpy)
Besides the longitudal v. transverse issue (no common mounting points) the F20C rotates the opposite direction of the B-motors. You would need some sort of reversing mechanism (unless you want 5 different ratios of reverse).
The B18C5 is the best it is gonna get (factory) for the cars that use the B-motors... which is pretty damn good.
Old Apr 6, 2002 | 08:51 AM
98TypeR's Avatar
Default Re: How hard would it be to yam an S2K engine into an integra? (D-Style)
yah, can't do it. They spin in different directions.
Old Apr 6, 2002 | 02:41 PM
Mac's Avatar
Mac
Default Re: How hard would it be to yam an S2K engine into an integra? (98TypeR)
A guy here in NZ is running a crx rally car with an s2k engine in it, front wheel drive. Nothings impossible...
Old Apr 6, 2002 | 02:48 PM
nsxtcjr's Avatar
New User
Default Re: How hard would it be to yam an S2K engine into an integra? (Mac)
...as you can see here.
Old Apr 8, 2002 | 08:59 AM
PatrickGSR94's Avatar
Community Builder
Active Streak: 60 Days
Default Re: How hard would it be to yam an S2K engine into an integra? (nsxtcjr)
Um no that car is RWD and the engine is in back, just like in the NSX. Not to mention that engine is meant to sit sideways just like in the NSX, while the S2K engine is meant to sit longways.
Old Apr 8, 2002 | 11:23 AM
dtmwerks.com's Avatar
some drag racer (I read it somewhere in a mag) WAS running a CRX with a Eagle Talong turbo engine, and rear wheel drive. He later put an S2000 engine inside. Nothing's impossible!
Old Apr 8, 2002 | 05:27 PM
MaxBoost's Avatar
New User
Default Re: How hard would it be to yam an S2K engine into an integra? (autorice)
No one said it's impossible, but that car is also a full tube frame chassis'd car...It's not a street car..
A NSX motor is probably easier than a S2k motor, just because for the S2k motor the tranny needs to have a driveshaft to connect to the rear differential..So you'd have to cut the car down the middle and make a transmission tunnel...That's majorily ******* with the car..
The NSX motor just needs a rear roll cage / tube frame, to have mounts welded to it. The tranny is designed to be in the back..and RWD, it would be much easier.
Old Apr 9, 2002 | 10:45 AM
blackDA's Avatar
Default Re: How hard would it be to yam an S2K engine into an integra? (MaxBoost)
The CRX w/ the NSX motor is in Lawrenceville, GA not NZ
4 door beast
Honda S2000
22
Dec 6, 2010 06:08 AM
530transam
Feb 2, 2007 07:06 PM
Dj Skidz7
Mar 1, 2006 10:39 PM
integ98_supraTails
Honda S2000
20
Jul 19, 2005 04:14 PM
integ98_supraTails
Jul 17, 2005 02:33 PM
