Widest tires possible
Old Mar 24, 2006 | 09:02 PM
professor poon's Avatar
Default Widest tires possible
unsuccessful search...
What are the widest tires I can run on an EM1 without them rubbing? Front wheels are not quite tucked. Thanks
Old Mar 24, 2006 | 09:13 PM
92hatchling's Avatar
Default Re: Widest tires possible (professor poon)
i wouldnt go no wider then 205 but maybe you could go 215 whats the suspenion set of the car ?
Old Mar 24, 2006 | 09:17 PM
posite's Avatar
205's are perfect. 215's might rub on hard cornering if they are almost tucked right now but dont quote me on that.
Old Mar 24, 2006 | 10:12 PM
old man neri's Avatar
Generally run no more than 20mm wider than original stock, no more than +3% bigger in overal diameter, and stick with your original offset and you should be fine.
Concentrate on getting better tires not wider tires.
Old Mar 24, 2006 | 10:24 PM
94_HATCH's Avatar
Default Re: Widest tires possible (old man neri)
there is a new 235 wide tire that a few boosted people are running with spacers up front. This is for serious street tire traction issues though and I dont know if they fit on the rear becuase ive only seen people use them up front.
Old Mar 24, 2006 | 11:05 PM
jadmEM1's Avatar
Default Re: Widest tires possible (94_HATCH)
Damn! A 235 tire on a civic!?!?!? That's one helluva setup. I run a 205 with no rubbing issues. Always thought about trying a 215 though.
Old Mar 25, 2006 | 06:36 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by old man neri &raquo;</TD></TR><TR><TD CLASS="quote">Generally run no more than 20mm wider than original stock, no more than +3% bigger in overal diameter, and stick with your original offset and you should be fine.
Concentrate on getting better tires not wider tires. </TD></TR></TABLE>
I plan on getting better AND wider tires...
molsoncanadian
Dec 5, 2014 08:59 AM
Outlaw-Hondaz
Jun 8, 2011 12:00 PM
717DC
Apr 5, 2010 09:12 AM
Integra21
Jul 8, 2005 05:57 PM
Audi RS4
10
Aug 27, 2002 08:04 PM
