radiator fan problem
Old Mar 24, 2006 | 12:37 PM
7808's Avatar
Default radiator fan problem
i noticed a few weeks back it seemed like my fan would come on and off too often and for too short of time, even when the car was cold. i've sence noticed the fan never comes on at all anymore. the other day i ran wires from the batt. straight to the fans harness and it came on.
this is on a 96 civic ex, what controls the fan? or what else could it be?
Old Mar 24, 2006 | 01:02 PM
Dodger2940's Avatar
Default Re: radiator fan problem (7808)
Change the fan switch, looks like this
Its on top of your thermostat housing. Might want to change your thermostat also. I had this happen to me and I changed all that worked great for a year then it all went to poop, now I just have a switch inside so I can turn it on and off.
Old Mar 24, 2006 | 01:08 PM
7808's Avatar
thanks i thought it was somthing like that.. do they sell these at auto parts stores or is it a dealer only part? (the switch)
Old Mar 24, 2006 | 01:20 PM
Dodger2940's Avatar
Default Re: (7808)
Yes they do. Sell them at both. I went with the OEM since its if I remember correctly under 20 bucks. Cont go wrong with OEM
Old Mar 24, 2006 | 01:38 PM
ek4d00r's Avatar
Default Re: (Dodger2940)
i bought mine at the dealer. thermostat and switch/sensor cost about $40 for both. i checked an auto parts store for the thermostat and they had it but they needed to special order the gasket. so i went w/ OEM
Old Mar 27, 2006 | 10:01 AM
7808's Avatar
guessing from that picture one from a 98ls wouldnt work in my civic huh
Old Mar 27, 2006 | 10:35 AM
littleredcivic's Avatar
keep in mind that the could be the switch OR the relay. ground out the lead to the switch and the relay should close to turn on the fan, if it does not...then you may have a faulty fan relay.
Old Mar 27, 2006 | 06:11 PM
7808's Avatar
i sitched the relay with the condenser fan one, whic i dont have anymore, and the fan switch out of my 98 integra. still dont come on.
Old Mar 27, 2006 | 06:50 PM
92civichatch1's Avatar
Default Re: (7808)
bump i got same problem
Old Mar 27, 2006 | 07:01 PM
92BlueCivic's Avatar
You can do a ghetto fix to that. You can bend a paper clip and push it into the fan socket. It basically hot-wires the fan. If the fan comes on when you put the paper clip in, then your fan switch is definately bad. Just replace it with an OEM part, as others have said its cheap.
Old Mar 27, 2006 | 11:10 PM
7808's Avatar
its like $43
Old Mar 27, 2006 | 11:12 PM
7808's Avatar
you mean jumper the clip to the fan switch pictured above?
Old Mar 28, 2006 | 06:38 AM
Default Re: (7808)
no u gotta jumper the connection that plugs into the fan switch.
Old Mar 28, 2006 | 11:59 AM
7808's Avatar
Default Re: (7808)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 7808 &raquo;</TD></TR><TR><TD CLASS="quote">you mean jumper the clip to the fan switch pictured above?</TD></TR></TABLE>thats what i said
Old Mar 28, 2006 | 12:32 PM
7808's Avatar
Default Re: (7808)
well i jumperd the plug that goes to the fan switch and all it did was make my check engine light stay on
kirkland08
Mar 5, 2011 01:15 PM
808MAUI
Feb 23, 2006 07:51 PM
twenty
Jun 14, 2005 07:35 PM
twenty
Jun 14, 2005 06:49 PM
