OEM GSR valve spring specs?
Old Mar 24, 2006 | 12:32 PM
straywalker's Avatar
Default OEM GSR valve spring specs?
Does anyone know the specs or have a link of specs for for OEM valve springs for a 94+ gsr. Im not looking for spring height but rather the Millimeters till spring bind or amount of lbs for example till the springs bind.
thanks
Old Mar 24, 2006 | 02:18 PM
JDMtype Eg6's Avatar
Default Re: OEM GSR valve spring specs? (straywalker)
intake valves .006-.007 and exhaust valves .007-.008
Old Mar 24, 2006 | 03:39 PM
Default Re: OEM GSR valve spring specs? (JDMtype Eg6)
Are you listing clearence specs? its just a lil vague. thanks
Old Mar 25, 2006 | 04:34 PM
yea those are clearance specs
intake: 0.006" - 0.007" (0.15mm - 0.19mm)
exhaust: 0.007" - 0.008" (0.17mm - 0.21mm)
Old Mar 28, 2006 | 12:23 PM
Default Re: (JDMtype Eg6)
I dont need clearence specs.
I need specs of the typical OEM gsr valve spring for bindining. Example: Spring compress's 70psi untill it binds. or how many Millimeters the spring compress's until it binds.
pheobo
Feb 19, 2006 03:23 PM
turbotypeR@SPEC
Nov 28, 2004 05:30 PM
mhgleitz
Nov 14, 2003 08:58 AM
